need help with power steering!!
#893306
06/29/08 10:42 PM
when i jerk to the left its easy (going forward)
when i jerk to the right its hard (going forward)
when i turn normal to the left its easy (going forward)
when i turn normal to the right the first little bit of the turn is hard then its easy.
when im going im going in reverse its easy turning left and right.. anyone else had this issue?
i just got the box from a junkyard and i have bleed the system.
Jay
85' Pickup, Crossover steering, 33x12.5 A/T, 4" lift
Re: need help with power steering!!
[Re: Azo]
#893307
06/30/08 09:24 PM
The last time i heard something similar was on a Pontiac, and virtually the same scenario. The final cure was a second trip to the junkyard and a second box to solve the problem. The steering had a "hard spot" part of the way through a right turn. Only thing I could figure was it sat for so long in the junkyard in one position. Who knows? You should also check the rest of your steering components thoroughly. A bad steering damper or even a loose tie rod end can cause the same sort of issues.
Richard S. 88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds Proud to be an American. Blessed to be a Texan!
[Re: Richards19884x4]
#893308
07/01/08 02:58 AM
i drove it today on the road for about 15 min. it seams to be going away.. mabey once i get it reg and inspected and drive it for a few hours it will go away???
[Re: Azo]
#893309
07/01/08 03:57 AM
Air bubbles in the system will do the same thing. Air gets into the system when first assembled and you need to let the fluid settle a bit, then refill.
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
[Re: toyrunner]
#893310
07/01/08 05:08 AM
Did you bleed the steering box?
"Serenity through Sobriety"
[Re: OOP'S]
#893311
07/03/08 05:49 AM
yes i bleed the system. twice
