Locker choices for 1991 4-cylinder pickup #893360 06/30/08 04:27 AM
52degrees Offline OP
Sorry for trolling your end of the forum, but I've got a buddy with a 91 4x4 pickup who actually listened to me when I told him to forgo the lift and spend the money on gears and lockers <img src="/forums/images/graemlins/zombie.gif" alt="" /> That almost made me fall out of my seat. Were it not for my seatbelt, and the door being closed and locked... nevermind.
Anyway, what are his choices for a selectable rear locker for his truck? I think he'd rather have something like an E-locker or an ECTED if possible. He doesn't really like the possibility of air leaks that come with ARB lockers.
TIA
KG6VNX
Re: Locker choices for 1991 4-cylinder pickup [Re: 52degrees] #893361 06/30/08 05:10 AM
OOP'S Offline
First off I have been running ARB's for 12 years F & R and neither of them has ever leaked.
I perfer ARB over the Toyota E-locker but that is just my opinion.
There is another E-locker that is being developed but I cannot remember who is making. Also Randys R & P is coming out with a clone of the early ARB that is made in China.
Tell your friend that 99% of the time if an ARB leaks it is installer error. Also I have been running the same blue air line in the rear that I put on 12 years ago.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Locker choices for 1991 4-cylinder pickup [Re: OOP'S] #893362 07/01/08 08:56 AM
Snowtoy Offline
X2 on the ARB. I have had the one in my "90 going on about 7yrs now and no leaks.
The one in my '91 leaked after about 6 engages on the trail, but that was because I didn't get the new style diff housing fitting tightened correctly, to little and it backs out/too much and you tear the O-ring. The leaks my friends have had have also been from either damaging the locker(backed into a rock and dented the housing), running the air line too close to the exhaust manifold, or a loose fitting, all operator error.
You can swap in a Tacoma/'96 newer 4-Runner e-locker with some modification to the non-Taco axle housing, or just swap the entire rear end in. The costs are about the same for a new E-locker/geared diff, and used prices are about the same as well. For the ARB, your buddy can either buy teh ARB compressor, or make his own using a small air tank, and MV50 Superflow(or other named) comp, an ARB pressure switch, and some air line fittings, and save about $100, less if he uses a used comp. I use an old air ride suspension compressor for my ARB, and a small air tank I fab'd up.
Re: Locker choices for 1991 4-cylinder pickup [Re: Snowtoy] #893363 07/02/08 12:43 AM
BROWNBAGG Offline
aussie lockers
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.5996 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-07-14 18:36:05 UTC
