Page 1 of 4 1 2 3 4
why all "water car/hydrogen generators" are scams #893788 07/02/08 03:04 AM
BigJim Offline OP
THIS IS A CUT AND PASTE from another site.. The guy seems to know his stuff.
I have recently seen many people attempting to prey on unknowing consumers, who are fed up with high gas prices, by advertising a supposed system, which splits water into hydrogen and oxygen, which is injected into the engine to be used as fuel. These systems are advertised as using an electrolysis process to split water into supposed "HHO gas," using electricity from the car's battery.
Obviously this scheme was thought up by someone who had never taken so much as a high school science class. Water ( HOH, not HHO ) can be separated into hydrogen and oxygen gas, by passing an electric current through it.
H20 (liquid) ---> H2 (gas) + 1/2 O2 (gas)
As you can see, by the above balanced reaction, for each mole Water (HOH) decomposed, 1 mole H2 gas is produced, and 1/2 mole O2 gas is produced
In order to preform the above reaction (electrolysis), energy is required. this energy is produced by the car's alternator, and stored in the battery. In order to produce electricity the alternator must place a load on the car's engine.
by looking at the enthalpy of formation of the electrolysis reaction
(Δ Hf rxn = 286 kJ/mol), we see that 286 kJ of energy is required to split 1 mole (18g) of water into hydrogen and oxygen.
The electrolysis process is only 20-30% efficient, (70-80% of the energy put in is wasted as heat), however, for the simplicity of this explanations (and to satisfy sceptics and nay-sayers), we will assume 100% efficiency in the electrolysis process. The alternator which generates the electricity for the electrolysis process, again is only 50-60% efficient, but again, for the sake of simplicity we will assume 100% efficiency. Finally, the internal combustion engine of your car is only 20-30% efficient, but again, for simplicity we will assume 100% efficiency.
when the hydrogen gas produced by the electrolysis process is burned in the car's internal combustion engine, hydrogen is combined with oxygen to form water vapour (steam), in the following balanced reaction.
H2 (gas) + 1/2 O2 (gas) --> H2O (gas)
by looking at the enthalpy of formation of this reaction
(Δ Hf rxn = -241 kJ/mol), we determine that 241 kJ of energy is released by the burning of 1 mole of hydrogen.
conclusion:
we determined that to split 1 mole of water into hydrogen and oxygen gasses consumed 286 kJ of energy, assuming 100% efficiency. we also determined that burning the same amount of hydrogen that was produced released 241 kJ of energy. Even assuming 100% efficiency, we still experienced a net loss of 43 kJ (15%) of energy from this process, which supposedly lets us use water as a fuel. simple calculations show that we actually lose 15% more energy creating hydrogen than is produced by burning it. These supposed fuel saving gimmicks will actually make you burn more fuel, by forcing your alternator to work harder to generate electricity for a process which results in a net loss in energy.
by figuring in the losses in energy throughout the electrolysis process, and combustion cycle (efficiencies given earlier), we can calculate that the process is only 3-4% efficient.
at 100% efficiency, 85% of the energy used for electrolysis would be returned to the engine to preform useful work, however, in reality just 3-4% of that 85% is actually converted in to mechanical energy.
This means that for every 100 kJ of mechanical energy taken from the engine by the alternator, only 2-3 kJ of mechanical energy is produced by this so called fuel saving system.
Re: why all "water car/hydrogen generators" are scams [Re: BigJim] #893789 07/02/08 02:16 PM
DBL_DTY97TJ Offline
Looks like he nailed it. I was surprised he has the alternator rated at 50-60% efficient....I thought that was actually high.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: why all "water car/hydrogen generators" are scams [Re: BigJim] #893790 07/02/08 04:05 PM
Bigbird79 Offline
This reminds me of one I heard a while back where a guy was talking about building an electric car that had the drive motor on one axle, then a generator on the other axle, so he could ôchargeö the batteries while he was driving down the road. And again, losses were not taken into consideration, so obviously it wouldnÆt work, but the way he presented it, it sounded great, until you actually used a little common sense and thought about it.
It amazes me all of the scams people come up with to prey on the public. If it were really that simple, some auto manufacturer would have already done it. Imagine even 5 years ago when fuel was under $2.00 a gallon, if auto manufacturer (fill in the blank) came out with a simple bolt on component/ device for an engine that doubled fuel efficiency, it would have been patented and they would have it on every vehicle they sold, and they would have likely put a huge dent in everyone elseÆs auto sales.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: why all "water car/hydrogen generators" are scams [Re: Bigbird79] #893791 07/02/08 06:57 PM
DBL_DTY97TJ Offline
Naaa....The oil companies would have bought the patent or the entire car company if they needed to and no one ever would have heard about it. They've done it before....
Re: why all "water car/hydrogen generators" are scams [Re: DBL_DTY97TJ] #893792 07/06/08 10:04 PM
Rauch_Off_Road Offline
I've done a bit of reading on this and it seems the idea isn't only to burn the Hydrogen but that the hydrogen makes the gas burn much more efficiently thereby gaining net benefit.
Its really a difficult thing to gauge though so I'll wait and see I guess.
(aka suprathepeg, aka Sean)
Re: why all "water car/hydrogen generators" are scams [Re: Rauch_Off_Road] #893793 07/11/08 10:56 AM
hlhneast Offline
So all HHO articles except those debunking it are scams? I know the American public will buy anything if they think its a "saving grace". I recently saw a Fox TV News Report from Clearwater about a guy that was developing an HHO generator for use as a welding gas instead of acetylene. He had also developed the technology and adapted his old Escort into a hybrid using the same tech. I understand the theory that if you are using alot of energy to produce a little of this HHO, it would not be efficient but if the energy is produced by your auto and comes from water and there is a net savings of fuel, it has to have promise. The Inventor had obtained government money to develop a Hummer using this as well as private industry interest. There are plenty of Thieves out there to scam folks but if this has promise, we need to explore it further. I do hold to the the fact that if it was viable, why isnt it in production right now? Hopefully, someone will use these foundations and finally produce something that will work someday. Should you buy the stuff out there now? Hell no, but someday, hopefully soon, the technology will be available to break the hold of our enemies on our throats over oil. It would be great to stop at the water crossing on the trail and fill up!! We need to dig up Tom Edison and clone him!!! <img src="/forums/images/graemlins/notooth.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
Re: why all "water car/hydrogen generators" are scams [Re: hlhneast] #893794 07/11/08 03:36 PM
BigJim Offline OP
Bama Using oil that is pushed by it's own pressure out of the well as with middle east oil mostly is.. Is a GIFT! We don't have to expend any effort to get our fuel.. All other fuels must be manufactured. So far all other fuels take more OIL to produce than they can replace.. So the effect is to stay with oil as less of it is used..
Then we come to wind, ocean waves, tidal movement and solar energy.. Then lastly Nuclear energy. These are the things that come to mind that may be almost as free as the oil is..
In my mind these are the things that must be made to power our lives..
Unless someone finds a way to separate hydrogen from other molecules for almost no use of other power.. it will be useless.. and is virtually useless right now, even though cars are being made to run on it. Each of these hydrogen cars is using more oil energy than MY CAR IS!
Re: why all "water car/hydrogen generators" are scams [Re: BigJim] #893795 07/11/08 03:39 PM
BigJim Offline OP
And by the way.. Alcohol! It takes more oil energy to produce corn based alcohol than the alcohol product that is the end result..
THE U.S.A. WOULD HAVE A NET GAIN IN OIL FUEL IF ALCOHOL WAS ELEMINATED FROM VEHICLE FUEL!!
Re: why all "water car/hydrogen generators" are scams [Re: BigJim] #893796 07/11/08 10:54 PM
cuervo25 Offline
Well isn't that only if your making moonshine runs <img src="/forums/images/graemlins/ignore.gif" alt="" /> lol seriously thats what ethenol is and e85 and so on is 85% corn ethenol the rest gas (I think) I understand it takes tractors and such to get the corn but if we get the immigrints to pick by hand that would cut a bit out of the oil prices,global warming and so on,heck at this rate i would drag my wife and son to the corn fields myself and pick corn by hand. there are tons of things that can be done but the gov't just will not put forth the effort if they know we will pay that price for fuel
Re: why all "water car/hydrogen generators" are scams [Re: BigJim] #893797 07/11/08 11:23 PM
jstritec Offline
SHHHHH!
The agricultural lobbyists might hear you.
80 CJ-7.
It runs
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6436 MB (Peak: 0.7735 MB) Data Comp: Off Server Time: 2026-10-29 07:12:02 UTC
