Stripped thread/missing nut, in frame repair #893930 07/03/08 04:47 AM
SavageSun4x4 Offline OP
If you are always working on your rig then sooner or later you will run into a nut in the frame that gets stripped or the tack weld gives way and the nut falls into the frame.
I have pulled off my front bumper more times than I can remember. Swapping winches, making alterations to the front bumper and then adding more to it. With each off/on cycle the bolts and nuts that hold your front bumper on take a beating.
Finally one of the nuts inside the frame that I could not get at fell off. It was the second nut in, on the right side of the frame.
Writeup/pics: http://www.savagesun4x4.com/enter/how_to_stuff/stripped_threadmissing_nut_.html
Don
Scottsdale, AZ
Re: Stripped thread/missing nut, in frame repair [Re: SavageSun4x4] #893931 07/03/08 05:28 AM
BobRowe Offline
Situations like that, in which component fasteners are repeatedly removed and reinstalled, can often be avoided by: (1) If threads are rusty, then chasing them with a tap or die to clean them up; (2 Using AntiSeize compound on the threads when re-assemblying the component; and (3) Torquing the fastener to the proper specification. Granted, that's more time and a little more work each time, but it usually saves a hellova lot of time and work at a later date. And, in somne cases, it means that trail repairs can be more easily affected.
Re: Stripped thread/missing nut, in frame repair [Re: SavageSun4x4] #893932 07/03/08 03:44 PM
DBL_DTY97TJ Offline
You can sometimes avoid the cutting by drilling the hole a little bigger (the new nut will never be perfectly centered and you need a bit of space away from the threads for the tack weld), cleaning the inside area of the frame with a small, bent file, then fishing a new nut through to the hole with a wire. Then tack weld around the edge.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Stripped thread/missing nut, in frame repair [Re: DBL_DTY97TJ] #893933 07/03/08 05:05 PM
I gave a lot of thought and considered several approaches. I settled on this approach for its simplicity, time to effort and strength.
If you have a welder and a cut off wheel this may be your best overall route to take...
Don
Scottsdale, AZ
PHP: 7.4.33 Page Time: 3.829s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-06-21 21:37:46 UTC
