Page 1 of 3 1 2 3
Pulled Montero engine #894134 07/05/08 07:43 AM
StockRaider Offline OP
I finished yanking the engine out of the blue Montero of mine. What surprised me is that I need to learn how to use either locktite or a torque wrench as most of the trans bolts were pretty easy to break loose. <img src="/forums/images/graemlins/scared.gif" alt="" /> Anyways, my next step is to get the engine on a stand and start tearing it down. I also noted I need to clean up and paint that engine bay. lots of rust. <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Pulled Montero engine [Re: StockRaider] #894135 07/07/08 07:12 PM
jdchappell Offline
those pics bring back haunting memories, i did that twice in 4 months, but I am pretty familiar with the truck now. I can change and adjust the timing belt in under 20 minutes now.
Re: Pulled Montero engine [Re: jdchappell] #894136 07/09/08 04:57 AM
I started taking the engine apart and found EVERYTHING has rust on it. valve covers getting rust bubbles, oil pan has bad rust flakes, and everything else has a nice coat of rust. I HATE road salt and I am glad RedHead Rebuilders are out of business.
Richard E
1983 Honda XL600R
Re: Pulled Montero engine [Re: jdchappell] #894137 07/09/08 08:36 AM
<img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Care to share you're step by step on this? I've changed the TB once (including other ancillary parts like the water pump, pulleys, etc. and it took a good 4-6 hrs. I can see cutting that down dramatically but 20 minutes?? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Pulled Montero engine [Re: off-roader] #894138 07/09/08 11:49 AM
FrankR Offline
I'll bring the popcorn. <img src="/forums/images/graemlins/lol.gif" alt="" />
Frank
Re: Pulled Montero engine [Re: FrankR] #894139 07/09/08 12:42 PM
Mad_Scientist Offline
I'm with Ray. It took me a good few hours to change the TB on mine <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Pulled Montero engine [Re: Mad_Scientist] #894140 07/09/08 04:57 PM
hazy_daze Offline
I can do it in about 2 1/2hrs with air tools and a tool helper. And that's after having done it a half dozen times.... Gotta call BS on 20 minutes, bro <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Pulled Montero engine [Re: Mad_Scientist] #894141 07/09/08 05:02 PM
jdchappell Offline
time moves a little slower down here. you know the astigmatisms us southerners have. big words i know, i went to one of them state colleges. It took me about 5 tries to get the tension right on the TB so I got real good as to which order to pull the bolts and what not, but if its a race your looking for im up to the challenge; after this 95 degree heat and 100% humidity goes away, lets say around January. my engine swap was a learning experience and honestly without the help from this forum and you guys I would probably still be scratching my head <img src="/forums/images/graemlins/scared.gif" alt="" /> thanks for all your help <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Pulled Montero engine [Re: jdchappell] #894142 07/09/08 05:41 PM
FrankR Offline
In case my truck's not running, would someone please stop by Columbia and pick me up on your way to Mississippi? I don't want to miss the fun. <img src="/forums/images/graemlins/lol.gif" alt="" />
I must be doing something wrong because the tensioner automatically sets the timing belt tension on my engine. But if it can be adjusted, I probably should learn how to do it. <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Pulled Montero engine [Re: FrankR] #894143 07/09/08 05:54 PM
hazy_daze Offline
I think you're on my way. You can ride shotgun...
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6417 MB (Peak: 0.7672 MB) Data Comp: Off Server Time: 2026-06-07 07:09:38 UTC
