axle play question #894263 07/06/08 02:15 AM
MAC Offline OP
While working on my ball joints, I noticed that I can push/pull on my axle shaft into the steering knuckle and it moves in and out a 1/4 inch or so. Tried same on other axle and it seems there is no play, although that side is on the ground. Anyone know if this is OK? Don't want to pull the hub (cone washers #$%^&!! ) and check the end bolt needlessly.
Re: axle play question [Re: MAC] #894264 07/06/08 03:38 AM
RatLabGuy Offline
I could be wrong, but if everything was kosher, I'd think the play you mention here should be held to a minimum by the bolt (10 mm head?) on the end of the axle shaft pinning into against the hub housing inside the hub.... IIRC, when you remove that bolt and the washers under it, you are able to then push the axle inward.
E.g., this suggests bearing play in the hub...??
Question Reality.
Re: axle play question [Re: RatLabGuy] #894265 07/06/08 10:09 AM
A
anotherjeff Offline
There should be a little end play. A C-clip (under the bolt and washer) determines how much end play. Your C-clip may be missing.
Re: axle play question [Re: anotherjeff] #894266 07/07/08 03:44 PM
MAC Offline OP
Yup, I better pull tht hub off... bet that darn clip is off.
thanks for the replies.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5997 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-06-02 07:34:43 UTC
