Timing/Misfiring #895892 07/16/08 10:14 PM
hoosiersporty Offline OP
I changed my spark plugs today along with the waterpump and timing belt. I cannot get my truck started. I used a chilton's guide to line up the pulleys properly but she wants to do is crank. Misfire in the plugs? TPS bad? I'm at a loss. Any ideas?
Re: Timing/Misfiring [Re: hoosiersporty] #895893 07/17/08 02:43 AM
DennisThompson Offline
Check all of your ground wires to make sure everything is conected. The first timming belt I changed I had the same problem and it turned out to missed ground wires.
Hope this helps, Dennis
Re: Timing/Misfiring [Re: hoosiersporty] #895894 07/18/08 04:27 PM
bombardj1 Offline
make sure the coil harness has a good connection they like to code a misfire if it does it pumps raw gas in the cats also and they code it could also jumped a gear or 2 on the T/B
PHP: 7.4.33 Page Time: 1.908s Queries: 15 (0.003s) Memory: 0.5917 MB (Peak: 0.6447 MB) Data Comp: Off Server Time: 2026-05-28 22:20:58 UTC
