Re: Running hot - first gen 4cyl auto. [Re: TainterRacing] #896164 07/20/08 03:25 AM
1987Raider Offline OP
No cat - never had one (at least not while I had it) - major exhaust leak where the downpipe hooks to the exhaust that goes out the back - that couldn't cause problems,could it?
1987 Raider 2.6L Auto -- rebuilt, by hand, by me -- Bouncy Seat/LSD/Aisin Hubs -- CB/Whip Antenna --Jensen Stereo -- Fire extinguisher .
Re: Running hot - first gen 4cyl auto. [Re: fasteddy] #896165 07/20/08 03:28 AM
I've thought of the torque, I guess I'll visit that soon.
2 row radiator.
Plugs look good - nothing out the back. (see above about the defroster smell).
Thanks!
Lee
Re: Running hot - first gen 4cyl auto. [Re: 1987Raider] #896166 07/20/08 03:37 AM
FrankR Offline
Checked the fan clutch, it's only a few months old - stopped immediatly when dead cold.
Now check it when it's hot.
Frank
Re: Running hot - first gen 4cyl auto. [Re: FrankR] #896167 07/20/08 02:48 PM
With the engine fully warmed (but not into the "running hot" situation I'm asking about) the fan turns 3-4 complete revolutions after the engine is shut off.
Been out since 6:00a.m. working on the truck, going back as soon as I grab a bite to eat. More later.
Lee
Re: Running hot - first gen 4cyl auto. [Re: 1987Raider] #896168 07/20/08 03:55 PM
FrankR Offline
Check it when the engine is in the "hot" zone. It should lock up. If not, the coil isn't allowing full hookup.
Frank
Re: Running hot - first gen 4cyl auto. [Re: 1987Raider] #896169 07/20/08 04:55 PM
tomzsix Offline
My 86 used to run hot, until I took out the 2- row and installed the original 3- row. Now it runs like it did 10 years ago.
Tom Tucker
Re: Running hot - first gen 4cyl auto. [Re: FrankR] #896170 07/20/08 05:13 PM
CapnCrunch Offline
Frank
Oh crap...I wasn't thinking about that clearly. Yeah, it should lock up when the engine's warm/hot and be loosey-goosey when the engine's cold. My bad.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Running hot - first gen 4cyl auto. [Re: CapnCrunch] #896171 07/20/08 06:55 PM
FrankR Offline
Actually, you were partly correct. It should be stiff when cold - otherwise, the fluid has leaked out. When cold, you shouldn't be able to spin it.
But as the fluid warms up, the fan will spin a little easier until the coil locks the clutch.... which allows a gradual engagement depending on temperature. If the coil goes bad, the fan will spin when hot even when it's full of fluid.
Frank
Re: Running hot - first gen 4cyl auto. [Re: FrankR] #896172 07/21/08 04:16 AM
CapnCrunch Offline
I was thinking one should be able to spin the fan easier by hand when the engine was cold, the purpose of the slippage being to allow the engine to warm up, and once warmed up the clutch should lock up allowing more cooling airflow.
I guess it's been a while since I gave my fan a spin by hand. [Linked Image]
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6359 MB (Peak: 0.7386 MB) Data Comp: Off Server Time: 2026-11-02 05:16:56 UTC
