Page 3 of 4 1 2 3 4
Re: Gen I 3.0 Crank Bolt Failure [Re: KrzyDav] #896487 07/24/08 11:10 PM
The washer should be a belleville type, with a slight dome which goes toward the bolt head. This puts a "spring" tension on the pulley at proper torque.
Re: Gen I 3.0 Crank Bolt Failure [Re: fasteddy] #896488 09/25/09 05:02 PM
4ePikanini Offline
for the record and future searches the bolt has changed again
it is the one on the right in the pic below. ( Thanks Frank )
measuring tape is an iso with mm and cm.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: Gen I 3.0 Crank Bolt Failure [Re: 4ePikanini] #896489 09/25/09 11:43 PM
sparkem Offline
I got one of those from hazy daze awhile back to put on my blue 91.
Re: Gen I 3.0 Crank Bolt Failure [Re: sparkem] #896490 09/26/09 12:45 AM
StockRaider Offline
wait, what about the updated bolt that was as long as the factory original just skinnier, were those somehow causing failure as well? <img src="/forums/images/graemlins/confused.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen I 3.0 Crank Bolt Failure [Re: StockRaider] #896491 09/26/09 12:48 AM
hazy_daze Offline OP
No. The latest design is just an update. If you have yours off, replace it with the updated one.
Re: Gen I 3.0 Crank Bolt Failure [Re: hazy_daze] #896492 09/26/09 12:53 AM
tyty Offline
I just insatll the one on the left in 94 sr 3.5
Re: Gen I 3.0 Crank Bolt Failure [Re: hazy_daze] #896493 09/26/09 12:55 AM
KrzyDav Offline
I have that updated one in mine. I hope it is not Chinese,,,Mitsu/KOYO/ ect.,etc. metal is all cast in China now. Bubbles in metal ,you know/
I have the 2nd improvement bolt and a Diamante bolt...one is going in real soon.
dave h.
Re: Gen I 3.0 Crank Bolt Failure [Re: 4ePikanini] #896494 09/26/09 01:16 AM
sasnydley Offline
The one I replaced mine look similar to the shorter looking ones- Except you could put a 1/2 ext inside the hex head.
Re: Gen I 3.0 Crank Bolt Failure [Re: 4ePikanini] #896495 09/26/09 01:18 AM
sasnydley Offline
Like these AND the washer was separate I think.
Re: Gen I 3.0 Crank Bolt Failure [Re: sasnydley] #896496 09/26/09 08:27 PM
KrzyDav Offline
The bolt for the 3.0 12 valve has a shorter unthreaded area than the 3.0 24 and 3.5 i.e the HB is thicker in the 3.0 24 and 3.5 .
dave h.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6438 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-05-30 02:10:10 UTC
