Re: Gen I 3.0 Crank Bolt Failure
[Re: KrzyDav]
#896487
07/24/08 11:10 PM
The washer should be a belleville type, with a slight dome which goes toward the bolt head. This puts a "spring" tension on the pulley at proper torque.
[Re: fasteddy]
#896488
09/25/09 05:02 PM
for the record and future searches the bolt has changed again it is the one on the right in the pic below. ( Thanks Frank ) measuring tape is an iso with mm and cm. ![[Linked Image]](http://img146.imageshack.us/img146/7208/crankbolt.jpg)
 Karma's Law - For every action there is a multiplied reaction! 93 Pajero GLS 3.0 V6 LWB - SOLD 2001 Gen3 Di-D LWB - SOLD 2005 Touareg R5 2.5 TDi
[Re: 4ePikanini]
#896489
09/25/09 11:43 PM
I got one of those from hazy daze awhile back to put on my blue 91.
[Re: sparkem]
#896490
09/26/09 12:45 AM
wait, what about the updated bolt that was as long as the factory original just skinnier, were those somehow causing failure as well? <img src="/forums/images/graemlins/confused.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#896491
09/26/09 12:48 AM
No. The latest design is just an update. If you have yours off, replace it with the updated one.
[Re: hazy_daze]
#896492
09/26/09 12:53 AM
I just insatll the one on the left in 94 sr 3.5
[Re: hazy_daze]
#896493
09/26/09 12:55 AM
I have that updated one in mine. I hope it is not Chinese,,,Mitsu/KOYO/ ect.,etc. metal is all cast in China now. Bubbles in metal ,you know/ I have the 2nd improvement bolt and a Diamante bolt...one is going in real soon.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: 4ePikanini]
#896494
09/26/09 01:16 AM
The one I replaced mine look similar to the shorter looking ones- Except you could put a 1/2 ext inside the hex head.
[Re: 4ePikanini]
#896495
09/26/09 01:18 AM
for the record and future searches the bolt has changed again it is the one on the right in the pic below. ( Thanks Frank ) measuring tape is an iso with mm and cm. Like these AND the washer was separate I think.
[Re: sasnydley]
#896496
09/26/09 08:27 PM
The bolt for the 3.0 12 valve has a shorter unthreaded area than the 3.0 24 and 3.5 i.e the HB is thicker in the 3.0 24 and 3.5 .
