Page 2 of 4 1 2 3 4
Re: Gen I 3.0 Crank Bolt Failure [Re: FrankR] #896477 07/22/08 06:57 PM
Mad_Scientist Offline
Good job Larry <img src="/forums/images/graemlins/kewl.gif" alt="" /> I didn't replace the crank on my '97 either when I changed the TB <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Gen I 3.0 Crank Bolt Failure [Re: Mad_Scientist] #896478 07/22/08 08:17 PM
And the victory dance went ok too???
Sorry y'all missed Rabun Bald trip. Buzz me when you try it again.
Re: Gen I 3.0 Crank Bolt Failure [Re: fasteddy] #896479 07/23/08 02:41 AM
Happy Birthday hazy_daze Offline OP
Victory dance went off without a hitch....
Definitely will call ya when we go again. I had the boys and Lisa with me Sunday. They all want to meet you. They want to hear some of your tales firsthand <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Gen I 3.0 Crank Bolt Failure [Re: hazy_daze] #896480 07/23/08 07:37 PM
Somebody check my numbers please.
According to Dodge (cause the Mitsu stealer guys are not nice <img src="/forums/images/graemlins/angry.gif" alt="" />) the most current P/N for the crank bolt is 1101A022 and the washer is MR994412. They said the numbers changed several times from the original number I gave them.
I ordered them for an 89 Raider 3.0, thinking it should be the same. The washer is flat and square shouldered on the ID and OD edge on one side. On the other side it's squared on the OD shoulder and beveled on the ID. I can't remember which side goes toward the crank.
As far as the bolt goes, it's 2.43" long. The diameter and pitch are correct. For some reason I was thinking the bolt was longer.
Any help on this would be appreciated.
EDIT: I remeasured the bolt and corrected my measurements.
Re: Gen I 3.0 Crank Bolt Failure [Re: hazy_daze] #896481 07/23/08 09:53 PM
Grasscat Offline
MD138069
Safety recall
Michael j
TreadLightly! Trainer
Re: Gen I 3.0 Crank Bolt Failure [Re: Grasscat] #896482 07/23/08 10:58 PM
Michael, do you have the bolt dimensions?
I just talked to Frank and he and I both agree that this bolt looks like a better design than the Mitsu part. It doesn't have the long shank between the contact shoulder and the hex. It goes from hex directly to contact shoulder then a very short bolt diameter shank then to threads. It may necessitate the use of a deep well socket rather than a shallow, but, to me that's a small price for, what looks like, a much stronger bolt. Thoughts anyone?
I'll post pictures of the bolt when I get home.
Re: Gen I 3.0 Crank Bolt Failure [Re: FrankR] #896483 07/23/08 10:59 PM
KrzyDav Offline
Make sure there is no woble when you hold the pulley snugged up in place . My crankshaft is now a smaller diameter from the lose pulley pounding the crank. It's not visable damage ,,, just loose.
dave h.
Re: Gen I 3.0 Crank Bolt Failure [Re: KrzyDav] #896484 07/24/08 12:23 AM
8
89IsMine Offline
Don't know if this helps or not, but here's a picture I snarfed off the forum a while back...
Old-style on the left, new on the right <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Eric W.
Re: Gen I 3.0 Crank Bolt Failure [Re: 89IsMine] #896485 07/24/08 01:44 PM
Thanks Eric! I like the way mine looks alot better. Mine doesn't have the ridiculously long part between the contact shoulder and the hex. Seems like this should be a stronger bolt. Got busy last nite and didn't get pictures up, but I'll get them posted tonite.
Re: Gen I 3.0 Crank Bolt Failure [Re: 89IsMine] #896486 07/24/08 10:42 PM
KrzyDav Offline
I recently ordered a Crank bolt from ..parts.com (i think) Korum Mitsu in WA. The improved bolt has been superceded by what looks like a hardened vertion of the caravan bolt.
It's short but installs just fine with a standard 6" extention.
dave h.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6482 MB (Peak: 0.7567 MB) Data Comp: Off Server Time: 2026-06-23 00:37:33 UTC
