trooper question #896550 07/21/08 02:40 PM
rhouser Offline OP
Hey everyone, without a service manual i dont know the names, but there is a nut that u tighten after u remove the lock outs that tighen the assembly, it was a lock washer with it also, do u need a special tool to tighter this?
Re: trooper question [Re: rhouser] #896551 07/21/08 04:35 PM
RobG Offline
i call it the front wheel/hub nut... and no, you don't need a special tool, you should be able to spin it using a screwdriver. how tight you make it determines wheel preload. if you want to be exact, you'll need a spring scale, attach to one of the wheel lugs, and measure how much force it takes to turn the wheel. IIRC, it should be something like 7 ft-lbs, but I mostly do this by feel now adays.
-Rob
Re: trooper question [Re: RobG] #896552 07/22/08 12:54 PM
rhouser Offline OP
i need the locking washer that goes with it, u know of a place to get one? its about the size of a can of chew and maybe 3mm thick
Re: trooper question [Re: rhouser] #896553 07/23/08 12:18 PM
RobG Offline
is likely going to be a dealer only part.
-Rob
Re: trooper question [Re: RobG] #896554 07/23/08 04:03 PM
lttlbddy Offline
. . . or junkyard.
Re: trooper question [Re: lttlbddy] #896555 07/23/08 06:31 PM
rhouser Offline OP
well untill i get my service manual i dont have a part number i even what the thing is called, i was told its a 4 dollar part
Re: trooper question [Re: rhouser] #896556 07/23/08 07:49 PM
RobG Offline
you don't need a part number, just a call and a good description (lock washer in front of hub nut) should be enough. or better yet, stop by your local dealership's parts department and you can look over the guys shoulder at their book and identify it on the exploded parts diagram.
-Rob
Re: trooper question [Re: RobG] #896557 07/23/08 08:24 PM
rhouser Offline OP
A isuzu dealer or are they owned by someone else now
Re: trooper question [Re: rhouser] #896558 07/23/08 08:35 PM
RobG Offline
no, an isuzu dealership, they still exist. or you could call St. Charles Isuzu if you'd rather, they've always been helpful to people on this board
http://isuzu.stcharlesauto.com/
for that matter, you could go to honda dealership and just lie and say you have a passport or slx.
-Rob
Re: trooper question [Re: rhouser] #896559 07/24/08 01:06 AM
bamashooter Offline
Go here and locate your part/part number. If you need help navigating through this, give me a holler.
shooter
http://www.myisuzuparts.com/
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6344 MB (Peak: 0.7390 MB) Data Comp: Off Server Time: 2026-06-09 01:35:46 UTC
