Re: trooper question [Re: bamashooter] #896560 07/24/08 01:21 AM
bamashooter Offline
Are you talking about item numbers 5 and 6? If so, item 5 is part number 8-94442-398-0 and item 6 is part number 8-94442-399-1. The 3 screws have part number 9-93090-408-0. Double check on the screws part # with whoever you order from. I ordered the screws and when they arrived, the heads of the screws were rounded and would not sit flush. The screws you need are flat headed machine screws. Hope this helps
shooter
Re: trooper question [Re: bamashooter] #896561 07/24/08 05:36 PM
rhouser Offline OP
yeap 5 is what i needed and got it ordered!! what is the best way to tighten down the hub nut?
Re: trooper question [Re: rhouser] #896562 07/24/08 06:16 PM
RobG Offline
didn't i mention that already? you can just spin it with a flathead screw driver and a light tap from a mallet. you're not gonna crank on it, just enough to get a light preload in the bearings.
-Rob
Re: trooper question [Re: RobG] #896563 07/24/08 06:23 PM
rhouser Offline OP
oh sorry my bad
Re: trooper question [Re: rhouser] #896564 07/25/08 07:44 PM
rhouser Offline OP
i got the lock washer but it doesnt look right, looks too small...i will find out this weekend
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6106 MB (Peak: 0.6749 MB) Data Comp: Off Server Time: 2026-06-20 18:57:22 UTC
