Pls. HELP. Electrical/starting problem. #896705 07/22/08 04:57 PM
9
90twodoorrunner Offline OP
I have 1990 V6 4runner 3slow.
Put in new Battery, alternator, starter is only 2 years old.
Problem:
Runner would crank but slowly and would start the runner after holding igition. this lasted a couple of weeks while it had good voltage.
I went away for 4 days came back wont start without jumping. after jump still has good voltage reading on dash. I checked all cables and all are good, good connection and everything, also checked alterator fuse and its good.
any Ideas? I know I should take battery in and get it tested but is there something IM missing?
1990 4x4 4runner 3.0L V6
the mystical two Door unibody
Re: Pls. HELP. Electrical/starting problem. [Re: 90twodoorrunner] #896706 07/24/08 02:23 AM
kewlynx Offline
Battery is the easiest/quickest way to start. I usually have the parts store do a load test before I walk out the door with it, as I live about 26 miles from the closest one.
**ubi apis- ibi salus**
Re: Pls. HELP. Electrical/starting problem. [Re: kewlynx] #896707 07/25/08 02:09 AM
Y
yotaman1224 Offline
with the truck runnin take off your neg. cable on your battery, if the truck stays running then your alt. prolly isnt the problem, i had this same problem with my big f-250 7.3L ford diesel and i cant stress enough your battery cables have to be the sh*t trust me, i had to spend the money and get all new battery cables for the ford (has 2 batteries 130 bucks for the main cable) and i put like 2 brand new grounds off each battery, and the thing would turn over like all the cylinders were shot it was amazing, i would also agree to take your battery to a parts store they can test it for you and tell you whats up, plus its free so why not <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5925 MB (Peak: 0.6456 MB) Data Comp: Off Server Time: 2026-10-24 13:55:22 UTC
