Oil change interval for 2.5 ITD? #896798 07/22/08 11:43 PM
Bernoulli Offline OP
I've been using Castrol Magnatec Diesel at 5000K. After looking at some of the intervals posted on http://www.bobistheoilguy.com/ I wonder if I couldn't go a bit longer. What are you guys using? Thanks!
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Oil change interval for 2.5 ITD? [Re: Bernoulli] #896799 07/22/08 11:48 PM
DonM Offline
I use Rotella T 15W40 and do it every 5K
1991 MITSUBISHI PAJERO EXCEED
Re: Oil change interval for 2.5 ITD? [Re: DonM] #896800 07/23/08 03:52 PM
tengopajero Offline
Also Rotella T 15w40 but every 10K. Change the filter (WIX) also.
Re: Oil change interval for 2.5 ITD? [Re: tengopajero] #896801 07/23/08 04:37 PM
4ePajero Offline
My 3.2 Di-D's service schedule allows up to 10000kms between services, provided 50ppm diesel is used.
I change at 5000-6000 in any case.
I would not advise 10k on the 4D56 engine!
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: Oil change interval for 2.5 ITD? [Re: 4ePajero] #896802 07/24/08 04:35 AM
Kurt1230 Offline
I use Quaker State HDX 15w40, every 5000 kms.
Diesels run dirty, I have heard of people changing it every 2500 kms.
1990 Mitsubishi Pajero 2.5tdi NG
31" Dueler A/T
Winter pack
Bright Lights
Re: Oil change interval for 2.5 ITD? [Re: Kurt1230] #896803 07/24/08 05:35 AM
torquemonster Offline
these old diesels always run black oil...after 5 minutes of running on fresh oil its black already. its not a big deal, if you run synthetic you can get 6000KM no problem out of the oil.
just look at how much industrial diesel engines (ie. generators, hydraulic pumps, whatever...) get used have a massive lack of maintenance. and they run forever.
my dad owns a service rig company and his light plants have 2.2L Isuzu diesel engines and they are poorly maintained but run for 50-60,000 hours problem free.
diesels are alot tougher than you think.
Re: Oil change interval for 2.5 ITD? [Re: torquemonster] #896804 07/24/08 05:59 PM
PHIL_ Offline
Nigel's right. A lot also has to do with how and where you're driving it. My regular drive is an hour on the highway, full warm-up, no starting and stopping, no quick starts/shutdowns, and a few minutes of slow speed at the end, followed by a minute or two of idle. This is 10 months of the year. I push my interval to 8500kms, fresh filter every time, synthetic Rotella.
Not saying this works for everyone, but it all depends on the conditions. As always, with any oil topic, everyone has an opinion, and the only right one is your own. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Oil change interval for 2.5 ITD? [Re: PHIL_] #896805 07/24/08 07:11 PM
redbull Offline
I'll second Phil's comments. Especially if you are running synthetic, you can go beyond 5000K. I've been alternating between Rotella-T (bought locally) and Amsoil (Cousin runs an oil change shop in Sask, so I get it cheap when I'm there.) I'm doing 7500K or so between changes. More often in the cold.
Re: Oil change interval for 2.5 ITD? [Re: redbull] #896806 07/24/08 09:44 PM
bae146 Offline
Well I did my oil change today and I even cut open the filter just for fun. Other than black oil I found nothing in the filter. I was interested as my last 5000 K's were through BC, up and down the Coquihalla, etc, and I was driving it hard. 100 kph on the hill up and out of Kamloops, so I was interested to see how the wear and tear was going. I found no metal at all. It is good to know that nothing is wearing out of the ordinary.
Re: Oil change interval for 2.5 ITD? [Re: bae146] #896807 07/25/08 02:07 AM
you should never find metal in your oil filter...if you do, its a bigger problem than wear and tear haha.
everybody says diesels run forever...and its for a very good reason, they are WAY overbuilt and can easily take a lack of maintenance (not saying that is recommended) but oil changes do not need to be as frequent as gas jobbers.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6341 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-06-22 10:54:13 UTC
