Resonator
#897226
07/24/08 05:48 PM
Can i yank the resonator and vacuum lines and shut them off ? I want to clean up the engine bay a little and it looks like it should be removed. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Resonator
[Re: 4Crawler]
#897228
07/24/08 09:26 PM
Yeah, I'M a dunce. lol
its a 90 22re
I was talking about the canister under the intake plenum that has a hose that goes to the airbox. Ive seen picts with that deleted but would like to know exactly what to do. Thanks for your help!
Re: Resonator
[Re: Brice]
#897229
07/25/08 01:53 AM
This is what I did with mine. Made a "Y" pipe for the pipes from the passenger side of the engine. Used a ABS cap, hose clamp, and RTV to block off the hole in the rubber tube in the bottom. Simple and easy and used mostly stock parts.
"Serenity through Sobriety"
Re: Resonator
[Re: OOP'S]
#897230
07/25/08 02:18 AM
I did this on my V6, and had a weird gurgling noise intermittently. Did you have that oops?
Re: Resonator
[Re: Adam F]
#897231
07/25/08 03:42 AM
on my 94 22re i just put a ebay intake on and had to plug the resonators hose. seems to run fine.
Re: Resonator
[Re: Adam F]
#897232
07/25/08 02:08 PM
I did this on my V6, and had a weird gurgling noise intermittently. Did you have that oops? Yep, that is one of the reasons they are on there.
