Vacuum leaks in 94 3.5 SR
#897461
07/25/08 09:38 PM
What have you experts out there found are common vacuum leaks on this model? I was told that one source of high hydrocarbons could be a vacuum leak, and I have that funky butterfly valve assy.
what hoses usually crack or leak?
thanks!
'94 Montero 3.5 SR, 202,000 mi.
Re: Vacuum leaks in 94 3.5 SR
[Re: Mike_Glenn]
#897462
07/25/08 10:30 PM
I just bought a bulk role of black tubing in the same diameter and went at all of em... you may have a few in the wrong place too...
87' Raider: off road package, rebuilt engine with (new) stock tires and alloy wheels but otherwise original.
[Re: Bhealy]
#897463
07/26/08 01:31 AM
Unhook the butterfly electrics, wire the arm in place, and RTV the shafts at the manifold.
[Re: fasteddy]
#897464
07/26/08 07:05 AM
good idea - which way should I wire them - long path or short for best smog?
thanks!
[Re: Mike_Glenn]
#897465
07/26/08 07:18 PM
Shouldn't make a diff. It's just a tuning aid for hp. The off at rest position should be right for low rpms, and I don't think the smog test gets to rpms above the changeover threshold.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6041 MB (Peak: 0.6679 MB) Data Comp: Off Server Time: 2026-11-14 19:24:42 UTCValid HTML 5 and Valid CSS
