Re: Carb options for 87 Dodge raider 4cyl [Re: KJ1223] #897705 08/02/08 04:46 PM
Look at the turbo bible post stickied near the top of the page. Follow the directions. Omit turbo. You're done.
Re: Carb options for 87 Dodge raider 4cyl [Re: KJ1223] #897706 08/02/08 06:39 PM
FatTony Offline
I am currently having problems with my carb. I want to put fi on it but can't find a conversion kit everyone i talked to can't help. Can you tell me how you solve your problem.
I looked into injecting a 2.6 a fair bit, the factory parts are hard to find and expensive. I was thinking about setting up a GM TBI on it with either a factory computer if I could get it to work or a stand alone setup. I lost intrest and decided to do an injected V8 swap, but I still think it's a good idea.
88 Raider sas, doubler, boggers
Re: Carb options for 87 Dodge raider 4cyl [Re: KJ1223] #897707 08/04/08 06:38 AM
KJ1223 Offline
I need some help. I have an 87 raider that the carb is causing me problem and i wish to replace it with fi if possible. I see in the forum about this aust. set up what all is needed to make it work and where can i get part to do it. i really want to do away with the carb set up there are to many lines to connect. someone pls help.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6024 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-20 23:01:55 UTC
