lower control arm #898136 07/30/08 04:37 AM
Bevoman Offline OP
I'm trying to get the CV shaft out to change the boots ('88 4x4 p.u.) but just can't get it to drop through the lower control arm. My local certified Toyota mechanic told me that at the dealer they drop the lower control arm. Sounds right to me but after disconnecting everything, including loosening the control arm bolts, sway bar bushing, and ball joint connections, it won't drop for anything! I've smacked it with a 4# hammer and broken a screw-in puller arm trying to push the ball joint shaft through. Is this thing just rusted fast or have I missed something? Any ideas on how to get the control arm to drop? Thanks!!
Hook 'Em
Re: lower control arm [Re: Bevoman] #898137 07/30/08 05:21 AM
Snowtoy Offline
Look at this post here Removing drive axle
Re: lower control arm [Re: Snowtoy] #898138 07/30/08 06:05 AM
OOP'S Offline
This is how my neighbor showed me how to do it. He is the Foreman at Roseville Toyota. This shows me doing it on a TRE but I have also used it on balljoints. Take the cotter key and nut off.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: lower control arm [Re: OOP'S] #898139 07/30/08 08:49 PM
anthony1 Offline
oops, I think he's talking about getting the front half shaft out by droping the lower A-arm.
I'll keep that in mind when I have to replace the it in the field. I think I used a ideler arm puller when I did my SAS.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: lower control arm [Re: anthony1] #898140 08/02/08 12:05 AM
DRTDEVL Offline
Don't drop the a-arm... Pound the studs out of the stub shafts, grind the splines off of them before re-installation.
With the studs out, the half-shafts will fall right out. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: lower control arm [Re: DRTDEVL] #898141 08/02/08 04:59 AM
RatLabGuy Offline
Eh, screw all that grinding.
Just but some Grade 8 bolts and locknuts.
Question Reality.
Re: lower control arm [Re: DRTDEVL] #898142 08/02/08 09:14 PM
OOP'S Offline
I know that but he said he broke a puller trying to get the BJ out.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6191 MB (Peak: 0.7100 MB) Data Comp: Off Server Time: 2026-07-15 12:58:03 UTC
