Rearend gasket "dried out"? #898267 07/30/08 09:41 PM
TatoHead Offline OP
Hey fellas,
I had to park the Trooper about 4 months ago due to gas prices, and instead bought a $300 econobox junker.
Out of the blue, I come home one day and there is a puddle under the rear dif. The leak is not coming from the drain plug, but rather the gasket, I think. The Trooper hadn't been moved in months, it just sat there and suddenly started leaking.
I'm kind of a newbie, but was wondering what I am looking at. Is this a difficult repair? Also, does anyone know what size the drain/fill bolts on the diff are? My largest socket, 22mm, was too small.
THANKS
1993 Trooper
"Purple People Eater"
Re: Rearend gasket "dried out"? [Re: TatoHead] #898268 07/31/08 02:13 AM
bamashooter Offline
Should be 24mm. Make sure you break the fill plug loose first. Hate to have it empty and not be able to refill. Just unbolt and pull the cover off. Give the surfaces a good cleaning and either replace the gasket or apply high temp RTV.
Re: Rearend gasket "dried out"? [Re: bamashooter] #898269 07/31/08 07:49 AM
maxwell417 Offline
In my 90 & 88 Troopers no gasket, just RTV. I think all 1st gens are RTV and suspect later ones are too.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Rearend gasket "dried out"? [Re: maxwell417] #898270 07/31/08 08:22 PM
Craig Offline
Are you sure it's not the pinion seal? That seems a more likely place for a leak to develop.
Buy a Trooper. You'll be glad you did.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5981 MB (Peak: 0.6539 MB) Data Comp: Off Server Time: 2026-07-13 17:23:26 UTC
