Re: help fixing vacuum leak around injector seal
[Re: Staceman]
#898463
08/08/08 05:04 PM
I did mine with .030 over. Rebuilt myself, AND I was dreading emissions testing, but she went through like a dream! That's very comforting to hear. Now, did you go through the emmision testing with your Air Flow Meter adjusted a couple of teeth richer? I currently have mine set two or three teeth richer to accommodate the larger displacement along with the cam and header.
'86 4x4 SR5 22re 5" lift 35" BFG's and 5:29 gears. '05 4x4 DC Tacoma TRD Sport
[Re: AZcoma]
#898464
08/08/08 05:51 PM
I never had to change my AFM and I have an over bored engine, cam, headers, bored throttle body, etc. Also have an A/F meter and the mixture is just fine with no AFM tweaks and I do pass CA smog.
[Re: 4Crawler]
#898465
08/08/08 07:47 PM
Never messed with the AFM. I adjust and/or tweek to stock specs whenever, where-ever possible. 'Cept for EB's cam. That is adjusted (valve lash) to His specs.
[Re: Staceman]
#898466
08/09/08 04:07 PM
sounds good. I'll set my AFM back to stock settings before heading to emissions on Tuesday. I marked the teeth with a white permanent marker so it's easy to go back. I'll also reset the ECU prior as well(of course). <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: AZcoma]
#898467
08/14/08 06:24 PM
Whoo hoo... passed emissions with flying colors! Now, afterwards I was tightening up all of the header bolts (installed a new LC engineering header) and found the top left header stud is stripped out in the head <img src="/forums/images/graemlins/angry.gif" alt="" /> So... what to do? remove and try to helicoil or is there a better way to repair this problem <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: AZcoma]
#898468
08/14/08 07:08 PM
You talking about the top bolt, closest to the firewall? Everyone has issues with that one. I go longer bolt first to grab in there. If that don't do it, you can tap it for a 7/16 bolt. (one size up)
[Re: Staceman]
#898469
08/14/08 08:31 PM
You talking about the top bolt, closest to the firewall? Everyone has issues with that one. I go longer bolt first to grab in there. If that don't do it, you can tap it for a 7/16 bolt. (one size up) Actually, its the top left (closest to the radiator). A longer stud would be great... Problem is where do you find a M10 metric stud at??
[Re: AZcoma]
#898470
08/14/08 10:00 PM
In a pinch, you can hit up ACE, get a long metric bolt, cut down to size. Basically a full lenth threaded stud.
[Re: Staceman]
#898471
08/14/08 10:05 PM
In a pinch, you can hit up ACE, get a long metric bolt, cut down to size. Basically a full lenth threaded stud. Good call, I'll give it a shot.
[Re: AZcoma]
#898472
08/15/08 02:52 PM
Just tighten in the head till snug. May strip out whats left of the threads otherwise. Mabe some red locktite too.
