help fixing vacuum leak around injector seal #898453 08/01/08 07:13 PM
A
AZcoma Offline OP
The #4 injector on my '86 22re refuses to seal for me <img src="/forums/images/graemlins/confused.gif" alt="" /> The seals are all brand new after I had the injectors sent out for flow balanced/cleaned. I didn't use any type of lubricant (other than gasoline) when installing the injectors. The first three are seal tight (using brake cleaner to squirt on all), but that darn 4th one always has a leak (really affects the idle when the cleaner is inhaled). So.. wondering what you folks would suggest to seal this up. Silicon gasket sealer, perhaps?? Other suggestions.
'86 4x4 SR5 22re 5" lift 35" BFG's and 5:29 gears.
'05 4x4 DC Tacoma TRD Sport
Re: help fixing vacuum leak around injector seal [Re: AZcoma] #898454 08/01/08 07:38 PM
4Crawler Offline
What all seals did you replace? There should be at least one o-ring and a grommet.
Re: help fixing vacuum leak around injector seal [Re: 4Crawler] #898455 08/01/08 07:40 PM
A
AZcoma Offline OP
yep, replaced the O-ring seals that are used for sealing into the intake and the grommets used to seal up against the fuel rail.
Re: help fixing vacuum leak around injector seal [Re: AZcoma] #898456 08/01/08 07:47 PM
Adam F Offline
vaseline
97 4R, stock, daily driver
Re: help fixing vacuum leak around injector seal [Re: Adam F] #898457 08/01/08 07:56 PM
A
AZcoma Offline OP
vaseline
Serious??
Re: help fixing vacuum leak around injector seal [Re: AZcoma] #898458 08/01/08 08:20 PM
Adam F Offline
As a heart attack. Its what we use on all the o-rings at work on aircraft fueling equipment.
Re: help fixing vacuum leak around injector seal [Re: Adam F] #898459 08/01/08 09:43 PM
A
AZcoma Offline OP
Cool! I'll give it a try this wkend. Thanks for the tip! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: help fixing vacuum leak around injector seal [Re: AZcoma] #898460 08/02/08 12:52 AM
Staceman Offline
Also make sure that there is no excess pressure, or pulling on the injector with the wire connection feeding it. I tried to make the wire harness "pretty" on mine, tucking it out of sight, but gave up, because 1 or 2 injectors leaked every time because the harness would pull the injector off center and outta line. Let the wires "relax" in their place, and you'll be good.
Re: help fixing vacuum leak around injector seal [Re: Staceman] #898461 08/06/08 03:57 PM
A
AZcoma Offline OP
Hooray!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> after replacing the intake manifold gasket (the guy who rebuilt my engine F'd up during the rebuild)and putting it all together, she purrs like a kitten. Perfect idle (had a serious lope to it with the gasket leak). Now, off for emissions testing next week. Anyone have their bored out engine not pass testing due to the increase in displacement?
Re: help fixing vacuum leak around injector seal [Re: AZcoma] #898462 08/07/08 06:24 PM
Staceman Offline
I did mine with .030 over. Rebuilt myself, AND I was dreading emissions testing, but she went through like a dream!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6415 MB (Peak: 0.7606 MB) Data Comp: Off Server Time: 2026-06-06 18:48:11 UTC
