Master Cylinder Wiring Connector Question #898998 08/06/08 05:44 AM
matts Offline OP
The '94 master cylinder I installed in my '84 has a wiring connector as pictured below. Any ideas on the range of model years that used this type of connector and if there is a possibility of getting a connector like that from Toyota or aftermarket sources? A '92 4runner I looked at had wires in the cap just like my '84. So I'm thinking this is a later configuration. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Master Cylinder Wiring Connector Question [Re: matts] #898999 08/06/08 06:19 AM
OOP'S Offline
The new MC I bought from Marlin has the same set-up and I am also looking for a plug. Maybe I am looking in the wrong place, Marlins web page says that the MC is for a FJ80. That may help in locateing a plug.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Master Cylinder Wiring Connector Question [Re: OOP'S] #899000 08/06/08 03:11 PM
CJM Offline
looks like the 99/00 4runner/Tacoma plug as well . 5VZfe.
you can check the "connector list " here
http://www.ncttora.com/fsm/2000/Wiring%20Diagrams/Connector%20List.pdf
The dealer I use to work for , at my parts counter , we had a OE connector book , so we were able to order OE connectors .. I would think all dealers should be able to .
83 Trekker SR5
NEW Trekker forum
Re: Master Cylinder Wiring Connector Question [Re: CJM] #899001 08/06/08 11:57 PM
matts Offline OP
Corey, I don't see it in the list/diagrams you provided, but I may have missed it. Are those pages from an FSM for a particular model year?
Below is a better picture (straight on view). The connector pictured is from a '94 brake master cylinder reservoir (fluid level sensor).
Re: Master Cylinder Wiring Connector Question [Re: matts] #899002 08/07/08 12:52 AM
4Crawler Offline
I think that is for a brake fluid low level sensor connection. My FJ80 m/c has that plug as well. I've heard that sensor can act up off road on side hills where the fluid sloshes away from the sensor. Not sure if it is just an idiot light or what that is connected to it.
Re: Master Cylinder Wiring Connector Question [Re: 4Crawler] #899003 08/07/08 02:07 AM
CJM Offline
yep exactly .. It's an idiot light .. but "sloshing" in the cylinder shouldnt be a Problem if your brakes are on par and top cover is sealed as NEW .
Matt .. I'll see if i can come up with the exact # for you ..
83 Trekker SR5
NEW Trekker forum
Re: Master Cylinder Wiring Connector Question [Re: 4Crawler] #899004 08/07/08 02:15 AM
matts Offline OP
Roger, it sounds like you haven't gotten yours hooked up yet either.
Re: Master Cylinder Wiring Connector Question [Re: matts] #899005 08/12/08 02:37 AM
CJM Offline
Matts
sorry .. no luck on the connector # ..
83 Trekker SR5
NEW Trekker forum
Re: Master Cylinder Wiring Connector Question [Re: CJM] #899006 08/12/08 04:32 AM
P
philly Offline
wow.. ok i put a 94 master into my 84 truck.. i even HAVE the wire for it.. i hooked it up.. using the 2 original wires. i tryed both ways. but it did not work. <img src="/forums/images/graemlins/frown.gif" alt="" /> offers on plug? <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Master Cylinder Wiring Connector Question [Re: philly] #899007 08/12/08 05:04 AM
matts Offline OP
Thanks to Corey for trying to find the connector.
One thing I noticed is that at least my idiot light stays off with the wires not connected. This is an improvement from the old arrangement where the light was on all the time, due undoubtedly to a faulty contacts in the old master cylinder cap.
Philly, when you say it didn't work, do you mean that the light was on even though the master was full or that it didn't come on when it was empty? Did you test the plug/wire for continuity? I'd give shipping and a few dollars for that plug and pigtail anyway. -- Matt
PHP: 7.4.33 Page Time: 0.966s Queries: 16 (0.007s) Memory: 0.6449 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-11-15 11:27:41 UTC
