Re: dana 30 oil seals [Re: BobRowe] #899277 08/08/08 07:04 AM
80CJ Offline
Actually, if you clean things up and look closely, Dana marks the bearing caps and nearby cover gasket surface with letters. One side will have a horizontal letter on both the bearing cap and cover gasket surface and the opposite side will have a similar letter oriented in the veritcal position in the like locations.
Re: dana 30 oil seals [Re: 80CJ] #899278 08/08/08 03:42 PM
Mudlover27 Offline OP
this is true, but I have had after market work done, so they may not be there, will see
cheers
Mud
98 wrangler 2.5l 3 inch rustys, 2 inch body, 33X12.5 MTR's DETROIT LOCKER, 4.88 gears, moser axles, Dana 44 (rubicon housing)
Re: dana 30 oil seals [Re: Mudlover27] #899279 08/10/08 06:07 PM
superdawg Offline
The letter stamping on Dana axle bearing caps are as permanent as any file mark, look closely for how they are indexed. No previous work in the axle could obscure or erase them. The down side of not looking for these marks is if they were installed wrong by the last person in there and you mark them the same way, you will reinstall them wrong too, and so on.. There should be no shims on the outside of the bearing races unless you are running an ARB.
SD
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5973 MB (Peak: 0.6503 MB) Data Comp: Off Server Time: 2026-06-21 11:10:13 UTC
