dana 30 oil seals
#899267
08/07/08 01:47 PM
hello all, Need to replace my inner oil seals on my dana 30, I know that I have to take out the diff, etc, my concern is when I go to put it back in (with the shims on the drivers side) do I need any special tools, or can I put it back together the exact way i too it out? cheers
98 wrangler 2.5l 3 inch rustys, 2 inch body, 33X12.5 MTR's DETROIT LOCKER, 4.88 gears, moser axles, Dana 44 (rubicon housing)
Re: dana 30 oil seals
[Re: Mudlover27]
#899268
08/07/08 02:53 PM
Yes you should be able to get her back to factory.. I always save the thickest shim for LAST.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#899269
08/07/08 04:20 PM
thanks the plan is do the seals the same time as I do new ball joints,
[Re: Mudlover27]
#899270
08/07/08 08:31 PM
On the Dana 30, the shims should be located under the bearing roller cones so you should not have mess with them. Just be sure to mark you carrier side bearing caps so that they can be re-installed in their original positions. Keep the bearing cups isolated or mark them with tags so they don't get switched around.
[Re: 80CJ]
#899271
08/07/08 09:51 PM
Thanks, i was planning on marking the vertical direction plus left and right with some marking paint (if it will stick) if I will mark it some how, thought though that there was a marking stamped on the B'caps . Thanks for the help Mud
[Re: Mudlover27]
#899272
08/07/08 11:57 PM
Or file a small notch in certain places on them.. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#899273
08/08/08 02:27 AM
Thanks that a great Idea, cheers
[Re: Mudlover27]
#899274
08/08/08 03:14 AM
I use a piece of the kids chalk to mark steel - for cutting or whatever - don't think it would cause a prob in a diff case.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD.
[Re: DBL_DTY97TJ]
#899275
08/08/08 04:03 AM
File marks never go away.. handeling, washing, scrubbing don't rub em off and they will still be there next time.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: Mudlover27]
#899276
08/08/08 05:06 AM
Buy one of those inexpensive electric vibrating engravers used to mark your tools. They do a great job marking the bearing caps and anything else you want to install back the same way it came apart.
