Replacing rotors - I'm stuck! #899718 08/09/08 09:56 PM
MR24Shoe Offline OP
OK, through reading several messages, was able to get the rotors off the truck (96 T100, 4x4, sr5).
using the wheels as a brace, I was able to work the bolts off of the back of the rotors that I thought were responsible for holding the hub on...but things won't get loose. I don't want to beat on it if I'm still missing some sort of fastener...
How do I get the hub off the rotor?
1996 Toyota T100 4x4 SR5 V6
1971 Datsun 240Z
Re: Replacing rotors - I'm stuck! [Re: MR24Shoe] #899719 08/09/08 10:03 PM
MR24Shoe Offline OP
found a recommendation for using a "pickle fork"...is this just done on the front side of the rotor between rotor and hub? just set the rotor straight up and down, and pound a pickle fork in there?
1971 Datsun 240Z
Re: Replacing rotors - I'm stuck! [Re: MR24Shoe] #899720 08/09/08 10:24 PM
MR24Shoe Offline OP
I was talked into some penetrating oil...and some "tapping"...we'll see...
Re: Replacing rotors - I'm stuck! [Re: MR24Shoe] #899721 08/09/08 10:37 PM
bkg Offline
if you're not re-using the rotors, just put a chunk of wood on the ground big enough to keep the hat off the ground. Hit it (the rotor) a couple of times with a hammer and it will come off.
Brian K. Gallus
Re: Replacing rotors - I'm stuck! [Re: bkg] #899722 08/09/08 10:45 PM
MR24Shoe Offline OP
alright...success...found an old chisel and worked it loose, w/ some oil, and the "blocks of wood" thing...finally.
Time to repack the grease and reassemble!
1971 Datsun 240Z
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6037 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-06-13 17:17:59 UTC
