2001-2004 4DR Taco with 5spd ?
#899741
08/10/08 01:45 AM
From what I understand toyota didnt make a manual trans 4 door tacoma. Has anyone put a 5 or 6 speed in a 4 door Taco? Is it easy or not happening? Im going to sell my T100 and want a four door taco but with a manual trans. Also do the auto trucks of the 2001-2004 come with 4.30 gears and the 5spd with 4.11 and does this change with the TRD package because I definatly want the rear locker?
95 T100 Xcab 4x4 1.5" ball joint lift 2" body lift,Downey shock mounts,All poly bushed,Milemarker hubs32/11.5/15 BFG/ATs
Re: 2001-2004 4DR Taco with 5spd ?
[Re: mrchills]
#899742
08/11/08 03:39 PM
Toyota Moderator
Go with the '05...manual trans, more power, same mileage, better ride, quieter, good aftermarket support.
Wheeling a Stepside Tacoma on 37s Exploring in a T4R Ltd V8
[Re: mrchills]
#899743
08/18/08 01:01 PM
It takes considerable adaptation (including ECU and wiring) to convert a 2001 - 2004 Double Cab to a manual transmission. Yes, it has been done.
An alternative approach - which is arguably 'easier' - is to transplant a Double Cab cab and bed onto a manual XtraCab chassis. I know of 3 examples of this approach (2 4X4's and my Double Cab S-Runner).
Both approaches require substantial investment and effort. Unless you absolutely need the smaller pre-2005 Tacoma and the inevitable hassles of a highly-customized vehicle, IMHO you're probably better off getting a 2005+ manual Double Cab.
Of _course_ I know the difference... I don't want you to kiss a hole in the ground.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5935 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-05-28 23:47:30 UTCValid HTML 5 and Valid CSS
