Page 5 of 5 1 2 3 4 5
Re: Ways to gain HP? [Re: DennisThompson] #899813 08/28/08 09:56 PM
Hydra747 Offline
What have you done to yours and what are your future plans?
I already have the Power,Gears and 2 types of lifts!
Chevy's are like that Denny!
I want a freakin' paint job (around $2200) <img src="/forums/images/graemlins/scared.gif" alt="" />
And as far as further cosmetics.....a new carpet, sound system and wheels.............
Oh well ---soon! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Good luck with your Ford....I like it. Maybe you or I would be lucky to go on "PIMP MY RIDE!" <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Ways to gain HP? [Re: Hydra747] #899814 08/29/08 07:39 AM
fokion Offline
I drilled the top distal end and implanted the temp sensor there.
That is the "why" mate... the ECU has correct info....
Re: Ways to gain HP? [Re: fokion] #899815 08/29/08 07:48 PM
logansportage Offline
I have used both the drop in K&N filter and the cone filter on my Sportage. The drop in works fine, but the cone filter is the way to go.
I took the top off the stock box and left the rest. Then drilled a hole in the rubber end of my cone filter next to where it mounts and installed the temp sensor there. It pushes right in if you use the right sizeed drill bit. I love it.
I have had it throw a couple of CEL codes, but that was because I used to much oil. I have not had problems sucking in "HOT" air, but the way Iron did it would be better because it would be more like a cold air intake.
Re: Ways to gain HP? [Re: Hydra747] #899816 08/30/08 01:58 AM
dorkpunch Offline
The Fuel filter is located on the bottom of the intake (in a tight little spot). Passenger side. Make sure that you engine is cooled down first. I burned my arm! <img src="/forums/images/graemlins/scared.gif" alt="" />
On my sport its kinda down on a frame rail near the rear... and my filter wasnt no $10 bucks, i think it was $35. Stupid SOHC sportages... That reminds me. Guess I should put it in...
Re: Ways to gain HP? [Re: Iron] #899817 08/30/08 05:46 AM
bombardj1 Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> put a firewall between the drivers seat and install a ramjet in the back <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Ways to gain HP? [Re: bombardj1] #899818 08/31/08 05:37 AM
Hydra747 Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
How about if they actually Change the oil and Air filter----Or Change the Exhaust setup?????????? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Ways to gain HP? [Re: Hydra747] #899819 08/31/08 07:10 PM
Iron Offline
Now look what you guys made me do!
All this talk about Cone filters made me go out and drop one on the jeep!
Not as much fun as making one from scratch like on the sporty, but it claims to give 9hp.
Regardles of what you drive the biggest difference is the amount of air the filter or intake sucks in, this goes for ANY stock or cone filter set up, The filter is not the limiting factor. The smallest opening or passageway the air must travel thru is more of a deciding factor than type of filter used.
Example on the jeep the stock box was limited to the amount of air the engine could suck thru the stock air box opening, which was the smallest opening at 8 square inches. The intake I have now the smallest opening is 14 square inches and that is at the throttle body, the filter actually has 160 square inches of filter going into a 16 square inch opening. Twice that of the stock filter set up. But only a 75% increase in possible air flow, as the limiting factor is now the throttle body which is now the smallest opening.
So sticking a cone filter on the end of a sporty intake all you are doing is removing the limiting factor of the factory air box which if I remember right was a mere 5 square inches at the intake above the rad. but you still have the limiting factor of the next smallest opening which I belive is the Mass air flow sensor and thats only a 6" opening so your increase in air flow is only about 20%.
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: Ways to gain HP? [Re: Adskia] #899820 09/20/08 07:50 PM
jaboo5322 Offline
"well......turbo IS on and almost sorted(exhaust manifold i made was to long so i have had to shorten it)....
only runing 6psi boost ......standard computer setup.......
intercooler is a pain in the arse to do....."
Any idea of horsepower increase doing this. Someday i would like to try.
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: Ways to gain HP? [Re: jaboo5322] #899821 09/23/08 05:06 PM
Adskia,
Any further updates or pictures on the turbo install?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6392 MB (Peak: 0.7458 MB) Data Comp: Off Server Time: 2026-05-29 17:14:08 UTC
