oil pump help #900527 08/14/08 09:31 PM
A
Anthony_89 Offline OP
I just put a timing chain in my 1992 toyota pickup... it has a 22re motor... the only thing I have left to do is put the oil pump on.. but I need advice on getting the gasget that goes around the pulley up front off.. and also how do I time the gears inside of it?
thanks in advance, Anthony
Re: oil pump help [Re: Anthony_89] #900528 08/14/08 09:59 PM
engnbldr Offline
>>>*Hi. The front oil seal can be removed by supporting the nose of the pump on each side and tapping it out with a simple drift or suitable rod.
There is nothing to "time" on the gears, just put them in, lube them well. Be sure when looking at the gears as installed you can see the little diamond shape on the side of each, that will be correct. Those should face the engine's timing cover....*EB
*Beats the he** outa me!....*LOL**...
Re: oil pump help [Re: engnbldr] #900529 08/16/08 12:44 AM
A
thank you very much.... I greatly appreciate it
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5900 MB (Peak: 0.6437 MB) Data Comp: Off Server Time: 2026-11-04 16:41:18 UTC
