Need an electrical connector #900712 08/15/08 05:40 PM
P
PLammer Offline OP
Hi all, does anyone know of a source of OEM type electrical connectors. I need this connector:
http://plammer.com/plammer/isuzu/DSCN0428.JPG
http://plammer.com/plammer/isuzu/DSCN0429.JPG
It's the one of the connectors that mates to the Aisin transmission. I understand the '90 and '91 Troopers in the US had Aisins, so I'm watching for one of those to be parted out. If I could find a company that sells these, that would be ideal as well.
Thanks!
Paul
Re: Need an electrical connector [Re: PLammer] #900713 08/17/08 12:57 PM
Van Offline
The easiest thing to do is to go to a junkyard if you've got one close by..... or auto parts store.
Go here to find the part #.... http://www.myisuzuparts.com/
Other sources for the part are.....
Jerry... PM JLEMOND on this forum.
Read this post.... http://forum.planetisuzoo.com/viewtopic.php?t=18448
Or here.. http://isuzu.stcharlesauto.com/Specials-Parts.aspx
Or here.. http://www.allhyundaiisuzuparts.com/
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: Need an electrical connector [Re: Van] #900714 08/26/08 04:32 PM
P
PLammer Offline OP
Thanks for the info. Unfortuately, it appears they don't sell the connector or harness itself, lots of other bits though.
I think my best bet is going to be to find a '89-91 with an AT that is being parted out. I can cut mine, but I'm holding off with thoughts of eventually using my computer for my transmission (I could cut the wires I have and splice them back if I do use the computer, just making an atempt to not cut the wires)
What I'm doing is side stepping my computer for my transmission for now and making it a push button shifted setup for now. If I can get that connector, I can do it without cutting any of the wiring that came with my setup. I'm making the process a little more difficult than it needs to be, but it'll give me more piece of mind. So possibly worth it smile
Paul
Re: Need an electrical connector [Re: PLammer] #900715 08/27/08 02:09 AM
Van Offline
You might try this company also.....
http://www.mouser.com/search/Refine.aspx?Ne=2355233&N=1323038+2355233&Ns=P_SField
Do a search on Google for "12 pin male automotive connector".... (that's what it looks like at least).
You can also PM this guy over on the Planet.... he normally makes junk yard runs (tell him I sent ya)..... http://forum.planetisuzoo.com/profile.php?mode=viewprofile&u=3259
HTH
NEVER give up...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6001 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-06-20 03:41:17 UTC
