NO REVERSE LIGHTS!!!
#901388
08/19/08 10:23 PM
Failed inspection for "no reverse lamps". Anyone know what could be going on? I have a 93 jeep grand cherokee with the 4.0 L and a automatic trans. Any advice would be greatly appreciated. Thanks Doug
Re: NO REVERSE LIGHTS!!!
[Re: 93jeepcher]
#901389
08/19/08 10:23 PM
Fuses and wiring are all good too.
[Re: 93jeepcher]
#901390
08/19/08 10:58 PM
Mine's a manual trans, and I don't know if they have any relation to each other at all w/regard to the reverse light switch, but mine has failed several times. On the manaul it's mounted on the outside of the tranny sort of up on drivers side IIRC and is pretty easy to get to and replace. If it functions the same way on the auto you should be able to plug a tester into it to check. OF course the auto is prolly some internal gizmo... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> Good luck.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD.
[Re: DBL_DTY97TJ]
#901391
08/19/08 11:14 PM
It is very similiar on the auto.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#901392
08/22/08 08:52 PM
I'm having the same problem, except when I take the switch out and press the button, the lights work just fine. Anyone ever have an SR-4 break internally so that it doesn't contact the switch?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6029 MB (Peak: 0.6663 MB) Data Comp: Off Server Time: 2026-06-23 12:47:33 UTCValid HTML 5 and Valid CSS
