looking at buying #901492 08/20/08 08:01 PM
Spike Offline OP
Found a 1990 Montero LWB LS 3.0 they said it had a blown head gasket. It has the Caution sticker and it is Auto.
WhatÆs the gear ratio and what is the Rig worth?
I know 2.6 L have problems with the head gasket do the 3.0L?
And should that worry me that itÆs "blown"
Spike
87 2.6L 5spd Dodge Raider
Yota Shackles and Crank,Superwinch Hubs
On 33's Thornbird
Re: looking at buying [Re: Spike] #901493 08/20/08 08:12 PM
LandRaider Offline
4.62:1
and what is it worth?
free to $1000 id say.
not as bad as the 2.6, but yeah.... don't overheat one.
Uhhhh yeah.. you're gonna have to fix that.
Re: looking at buying [Re: LandRaider] #901494 08/20/08 08:22 PM
Spike Offline OP
Ok, so I fix it.
What underling problems would have caused this, and will the over heat have damage other systems?
Is their any previous discussion on the 3.0 blown head gasket.
Spike
On 33's Thornbird
Re: looking at buying [Re: Spike] #901495 08/20/08 08:26 PM
LandRaider Offline
Ok, so I fix it.
Cooling system will prob need attention. Radiator rodded, or recored, new water pump... timing belt also.
Yes Lots.
Re: looking at buying [Re: LandRaider] #901496 08/22/08 04:17 AM
Use these search terms:
Username = FrankR
Search terms = "head" and "head bolt"
Do that stuff you find in those posts and it will be perfect. Use the quote marks in your search.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6075 MB (Peak: 0.6730 MB) Data Comp: Off Server Time: 2026-06-10 03:12:38 UTC
