rear axle #901893 08/23/08 07:03 PM
N
nateyesme Offline OP
I have a 93 toyota 4x4 with the 3.0. I was looking under the truck the other day and twisted the drive shaft and noticed a lot of play with it before it would hit in the rear axle gears. Is this a sign of great wear?
Re: rear axle [Re: nateyesme] #901894 08/23/08 07:15 PM
Adam F Offline
Its possible.
Could be other things though. Pinion nut could be loose and its not meshing properly with the ring gear.
Could be a worn out u joint.
You need to pull the drive shaft and check things out.
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5861 MB (Peak: 0.6338 MB) Data Comp: Off Server Time: 2026-06-03 13:11:34 UTC
