91 Montero Will Not Start Any Ideas #902302 08/26/08 03:12 PM
Dan1171 Offline OP
My 1991 Montero 3.0 automatic will not start. The engine light came on and I pulled over to see why and didn't find anything and then it would not start (It would turn over though). After messing with the coil, battery connection, it started back. Now it will turn over, but will not crank. I disconnected the coil wire from the distributer cap and it will spark every now and then. I know it could be the ignition module, coil, or computer. Is there any way to check and narrow down the possibilites.
Re: 91 Montero Will Not Start Any Ideas [Re: Dan1171] #902303 08/26/08 09:50 PM
8
89IsMine Offline
Why sure! Go get this: No Start + Driveability Diagnosis (1989, but should be mostly applicable to your '91 I would think...)
Courtesy of one of the great members on this forum -- MontyMcV! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
In my case the issue was a bad fuel pump (what I originally suspected, but the manual helped to verify it).
Good luck!
Eric W.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5879 MB (Peak: 0.6362 MB) Data Comp: Off Server Time: 2026-06-10 13:44:34 UTC
