valve's man, valves
#902995
08/29/08 08:58 PM
I've decided to go with a 261c cam and engine kit for my 22r. My question is this: Are there any special tricks or tolerances to be followed when adjusting the valves on this cam or do I just follow my repair manual instructions? <img src="/forums/images/graemlins/confused.gif" alt="" />
If a man throws a wrench and no one is there to see it; does it still count as pitching a fit?
Re: valve's man, valves
[Re: Knucklepin]
#902996
08/29/08 09:06 PM
EB will give you the values when they ship the cam. Should be marked on the box. Mine is 6 and 9 thou. Stock is 8 and 12.
[Re: Knucklepin]
#902997
08/29/08 10:27 PM
>>>*All three designs we have are now tight lash lobes, set them at .007" intake and .009" exhaust. Ted
*Beats the he** outa me!....*LOL**...
[Re: Knucklepin]
#902998
08/30/08 02:11 AM
[Re: kewlynx]
#902999
08/30/08 04:06 AM
Thank you for that Kewlynx. That was good information and a really simple cut and dried explanation. Now, all that being said; will the cam and timing set that comes with my kit be fully adjustable? I'm used to a chevy, which have all the adjustment on the crank gear, line up the dots and away you go (barring any serious material removal from the deck or head.) If it isn't fully adjustable; then how likely am I to have to adjust the cam one full tooth one way or the other? Or am I just not getting it? <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: Knucklepin]
#903000
08/30/08 06:00 AM
>>>*One full tooth would be a LONG ways! That isn't likely to ever be required.
On a few engines that have had a lot of head/block material removed we find a degree or two can make quite a difference.
On most of the 22R/RE engines it is bolt it up and go....*EB
[Re: engnbldr]
#903001
08/30/08 07:10 AM
Thank you again. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6173 MB (Peak: 0.6915 MB) Data Comp: Off Server Time: 2026-11-02 12:18:36 UTCValid HTML 5 and Valid CSS
