94 yj clutch not fully disengaging
#903108
08/30/08 09:25 PM
Is there any way to bleed hydraulic system for the clutch on a 94 wrangler?
Your road to glory will be rocky, but fulfilling. - Panda Express fortune cookie
94 YJ. no lift...YET
Re: 94 yj clutch not fully disengaging
[Re: the_other_guy]
#903109
08/31/08 05:39 AM
Could you be a little more explicit with your question?
The subject line says one thing while the content points to a different issue.
Based on the subject line, I would offer that you have a throw-out bearing issue. (BTDT with my 94 YJ resulting in a new throw-out bearing and clutch).
If you want to "bleed" the hydraulic line ---- it is a fill the container and pump the clutch and check level and fill as needed.
It does not require bleeding as do brake systems.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5853 MB (Peak: 0.6331 MB) Data Comp: Off Server Time: 2026-06-06 23:49:08 UTCValid HTML 5 and Valid CSS
