87 4runner replacing idler arm bushings #903161 08/30/08 11:24 PM
hazman Offline OP
Can the idler arm bushings be replaced on the vehicle or do I need to take the unit off? Is a press needed to replace/install these bushings?
Re: 87 4runner replacing idler arm bushings [Re: hazman] #903162 08/31/08 12:00 AM
P
philly Offline
Re: 87 4runner replacing idler arm bushings [Re: philly] #903163 08/31/08 12:22 AM
hazman Offline OP
Thanks Philly! Exactly what I needed to know.
Re: 87 4runner replacing idler arm bushings [Re: hazman] #903164 09/02/08 02:37 AM
MAC Offline
you do not have to pull the joint (idler arm stud to steering link) apart. you can take the body off the shaft. leave the shaft attached to the steering link... less work and potentially ruining the rubber.
PHP: 7.4.33 Page Time: 2.134s Queries: 15 (0.003s) Memory: 0.5992 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-06-21 09:44:39 UTC
