Greasing speedo cable
#903275
08/31/08 03:48 AM
I need to grease the speedometer cable on my CJ7. It's not very old (less than 200 miles), but I forgot to grease it when I recently replaced it. I don't want to buy another batch of grease. I have the following greases available in my garage:
1. Chassis grease 2. Wheel bearing grease 3. Lubri-Plate (white lithium grease) 4. Dielectric grease 5. Vasoline patroleum jelly
Which would you use?
Re: Greasing speedo cable
[Re: BobRowe]
#903276
09/02/08 04:38 PM
Bob it prolly has all the grease in it that will be needed but If you just MUST take it apart I'd be for looking at what is in there already and copying it.. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BobRowe]
#903277
09/02/08 08:09 PM
I've used bearing grease on all sorts of cables and never heard another peep outta them. I'm sure white lithium would do fine too.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD.
[Re: DBL_DTY97TJ]
#903278
09/03/08 01:44 AM
White lithium grease should not be used on speedo cables, because it will attack the fabric core of the cable. Heavy wheel bearing grease might cause problems, if you live where it get's c...ccc..cold......Vasoline should work fine <img src="/forums/images/graemlins/scared.gif" alt="" />.....be cool...Mike <img src="/forums/images/graemlins/oink.gif" alt="" />
2013 Wrangler Rubicon, 2014 Jeep Cherokee Latitude, 09 Mercedes Benz ML350 4matic...Old scooter trash trying to do good, in the flat lands of Indiana
[Re: Mike Bondi]
#903279
09/03/08 02:31 AM
Thanks for the suggestions, guys.
BTW, it didn' have lube on the inner cable when I got it. I made a mental note to grease it before I installed it, but then somebody stole the note!
[Re: Mike Bondi]
#903280
09/03/08 01:56 PM
White lithium grease should not be used on speedo cables, because it will attack the fabric core of the cable. oop. My bad.
[Re: BobRowe]
#903281
09/03/08 03:45 PM
BTW, it didn' have lube on the inner cable when I got it. I made a mental note to grease it before I installed it, but then somebody stole the note! Yup! That'l happen! And by the time you are 70 or so you won't even remember to type it in here.. Ask someone that knows.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#903282
09/04/08 09:17 PM
Yup! That'l happen! And by the time you are 70 or so you won't even remember to type it in here.. Ask someone that knows.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" /> Horrors!!!! I only have about 2-1/2 years to go... and already I have repeated esipodes of CRS syndrome! <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: BobRowe]
#903283
09/15/08 10:14 AM
Mike Bondi, back at it, how the heck are you?
SD
[Re: superdawg]
#903284
09/16/08 04:38 AM
Life is Good!! You know I have a difficulty in staying quiet....Be cool..Mike <img src="/forums/images/graemlins/oink.gif" alt="" />
