Posting images #903895 09/03/08 06:55 PM
BobRowe Offline OP
I recently tried to putting a couple of photobucket images in a post of mine, but all I got was text, not the image. I used the "image" selection button to do so, but I must be doing something wrong.
The post is #1115069 in the Jeep Talk forum.
Help...
Thanks,
--Bob
Re: Posting images [Re: BobRowe] #903896 09/04/08 05:23 AM
Bob,
You're in the right ballpark. You have your photos hosted. When you're at the Photobucket site, click on the "Direct Link" line, second under the image. Make sure you get the entire information string, copy and paste the entire string into the 'Image' box which pops up with "http://___" and press return.
Review your post before finalizing. You should be good to go.
I fixed up the pictures for you in that thread, some of the picture coding ("?t=1220463780") was causing the error.
Russell <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5878 MB (Peak: 0.6361 MB) Data Comp: Off Server Time: 2026-07-15 00:05:23 UTC
