POR-15 and NEW bed ...... #904104 09/05/08 02:33 AM
CJM Offline OP
so customer "Chad" brought this to me late last week .. he's from Calgary .
I didnt get a shot of the truck with the bed on .. but believe you me , it was bad .
I got the box off .
and started to clean up the frame ..
second day , I got on cleaning again .. inside and out
I used a small air chistle , and wire brush .. and "chipped" off all the rust ..
worked very well ..
as the truck sat overnight , ran into a small problem .. as usual , the brake lines were rusted , and just needed that little "hose action" to reviel a pin hole .. you can see it soaked the frame ..
so in order to fix this .. I had to remove the fuel tank ..
and of course with that .. the fuel line breaks .. as well as almost every bolt !!
so now with the fuel tank removed .. you can clearly see the problem ..
new parts ordered ..
couple of more things ..
I'm replacing the shackles , as they were siezed solid , and removal was difficult .
repaired the spare winch .. now it works !!
[img]http://i76.photobucket.com/albums/j2/bj_bumperboy/chads%20truck/HPIM0916.jpg[/img]
and also .. continued on cleaning the internal frame rails .. 2ND cleaning pile ..
[img]http://i76.photobucket.com/albums/j2/bj_bumperboy/chads%20truck/HPIM0921.jpg[/img]
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904105 09/05/08 02:55 AM
kewlynx Offline
Did you hit the spare tire winch with Kroil, or do some beadblasting, or a little of both? Ya make me cringe about my '83.
**ubi apis- ibi salus**
Re: POR-15 and NEW bed ...... [Re: kewlynx] #904106 09/05/08 04:11 AM
CJM Offline OP
I got lucky on that one ..
I was able to use pry bar (after soaking with "viner-schlider" for a day) inching it back and fourth .. and finally breaking it loose ..
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904107 09/06/08 01:27 AM
CJM Offline OP
ok .. so a little more today ..
I ordered a new fuel pump bracket , and even a diff vent smile
continued working on getting the inside clean .. I "reduced" the vaccuum hose , so I could vac up the some of the pieces that just didnt want to come out ..
I was able to pull some of the larger chunks out .. and then "suck" up the smaller debris .
and one more air blast , and wash , and it'll be good to go ...
also ..
finished the repair on the brake line ..
and also got the new shackles and bushings on .. LOTS of neversieze , and ..WOW the suspension actually works like it should now .. smile
and also had to drill and tap some broken bolts .. did them on the frame , and also the fuel filler tube ..
all washed and cleaned up .. I started the POR-15 treatment
truck is now sitting in the shop over the weekend to "dry out" from the last clean and wash .. so MONDAY .. I'll be doing the frame .
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904108 09/08/08 05:12 AM
Toy4x Offline
I did the POR 15 on my tank & parts, nothing but good things to say.
Look forward to seeing the frame progress
Re: POR-15 and NEW bed ...... [Re: Toy4x] #904109 09/09/08 01:59 AM
CJM Offline OP
thanks .. and I like it too !!!
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904110 09/09/08 01:59 AM
CJM Offline OP
so POR-15 is all done ... inside and out ....
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904111 09/09/08 03:40 PM
Red_Chili Offline
Toyota Section Staffer
How did you get the POR on the INside of the frame?
If you PORd the bumper you want to put Chassis Black over it before it fully sets up. DAMHIK.
Did you weld plates over the thin, pinholed portion of the frame ahead of the spring hanger? If not, in a few miles he's gonna have a "Brokeback" Toyota.
-Bill
Re: POR-15 and NEW bed ...... [Re: Red_Chili] #904112 09/09/08 05:07 PM
bkg Offline
Want to know the same!
Brian K. Gallus
Re: POR-15 and NEW bed ...... [Re: CJM] #904113 09/09/08 11:17 PM
P
philly Offline
about how much por15 did you use on that back half?
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6473 MB (Peak: 0.7731 MB) Data Comp: Off Server Time: 2026-10-21 22:12:48 UTC
