Rear differential pinion seal #904546 09/08/08 01:55 AM
joe_hockey Offline OP
My rear diff. seal is also leaking and I've been reading this stuff about checking the drive pinion preload before removing the nut. Is this something you guys do or should I just remove the nut insert the new seal and torque the nut back on?
95 4Runner, SR5, V6, 4x4, Automatic, 191k miles
Re: Rear differential pinion seal [Re: joe_hockey] #904547 09/08/08 02:59 AM
SantaCruz4Runner Offline
It would be a good idea. If there is a crush sleeve then there is the possibility of adding more preload, by the turn of a nut..
1986 4Runner SAS 4.3/700R4/4.7/4.88 and some stuff
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5861 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-06-11 12:41:27 UTC
