Tranny and T case oil #904688 09/09/08 06:17 AM
G
gerry_p Offline OP
I appreciate all the advice I get on this site. I'm the guy with the 52 Willys with a T10 tranny (yes I know the gears are too high) and the original Spicer 18 T case. When I top up the oil in the tranny and the T case and then run it, the tranny oil level is low and the T case oil level is overfull. Are they supposed to share oil back and forth or do I have oil leaking from the tranny to the T case.
Gerry
Re: Tranny and T case oil [Re: gerry_p] #904689 09/09/08 02:25 PM
Bigbird79 Offline
The T10 lube "system" is self contained, and should not be "leaking" into the transfer case.
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: Tranny and T case oil [Re: Bigbird79] #904690 09/09/08 03:00 PM
BigJim Offline
Yep! What he said..
Re: Tranny and T case oil [Re: BigJim] #904691 09/09/08 06:34 PM
Bigbird79 Offline
We did used to have a T10 in the Late Model, until we switched to a Saginaw 3 speed for less rotating mass, and it did develop a leak, but that was due to a cracked aluminum housing.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5995 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-06-10 19:05:56 UTC
