Winch way?
#904917
09/11/08 04:25 AM
I had a chance to use the X8000i for the first time today, and I've come to 5 conclusions:
1) Jump starter boxes can't power a winch worth a damn. <img src="/forums/images/graemlins/barf.gif" alt="" />
2) Winches, when used with a proper power source, freakin' ROCK! <img src="/forums/images/graemlins/kewl.gif" alt="" />
3) Having a reciever to connect your reciever-mount winch to probably works much better than chaining it to the bumper. <img src="/forums/images/graemlins/shiner.gif" alt="" />
4) But the bumper still works. <img src="/forums/images/graemlins/nana.gif" alt="" />
5) I don't have clue how to wind the winch back up. <img src="/forums/images/graemlins/confused.gif" alt="" />
What I mean by number 5 is that; can I just spool in willy-nilly, or should I unwind it and get a nice left-right stack wind on it?
I'll assume the later, but I thought I'd check.
Thanks,
Wagon Master
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
Re: Winch way?
[Re: WagonMaster]
#904918
09/11/08 09:35 AM
To keep from ruining the cable, you want to wind it up nice. Anchor the hook to something immobile and winch your vehicle up to it in neutral or with a little brake just to keep the cable taught while you carefully guide it neatly onto the drum. Use heavy gloves and dont be tempted to let the cable slide through your hand... hand-over-hand it.
91 Montero LS,3.0L,auto,off road pkg. 89 Trooper S,2.6L,5 spd 07 Dodge Ram 2500 4x4,5.9L Turbodiesel,6spd "Non Vi Sed,Arte"
Re: Winch way?
[Re: DREDnot]
#904919
09/11/08 10:57 AM
I suggest that you check on Pirate4x4.com & find the winching bible. Billavista did a very good writeup on it.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity. "How can I break it better?" 89 Raider 3.0 w/ 31's for now
Re: Winch way?
[Re: WagonMaster]
#904920
09/18/08 02:02 AM
Thanks,
Wagon Master I have a Warn X8000i also and it work's ok, about the mounting i remember reading about the 2" receiver hitch that it's rated for only about 5000 pound so you must be careful as you may end up with a airborne winch.
Re: Winch way?
[Re: WagonMaster]
#904921
09/18/08 02:06 AM
You can download the wiring diagrams i made from this link if you want to keep them for reference wirings Warn X8000i
