Block heater #906212 09/19/08 05:24 AM
F
Flannelman Offline OP
So I just moved to Montana and now I need to see about getting a block heater for my truck since its actually gets cold here(-40F). So I was wondering what the best option is for one? I heard Toyota maybe one that replaced the freeze plugs but I haven't found a link to anyone that sells it. So would a pan heater to heat the oil be better or should I try to find one of the Toyota heaters?
Thanks
1997 T-100 100k and counting Green
5spd 4x4 Ext Cab isr mod Aisin Manual hubs
Re: Block heater [Re: Flannelman] #906213 09/19/08 05:43 AM
kewlynx Offline
The oil pan heat pad to me is a must, given that oil gets to be like molasses in the cold, and you won't pickup oil that first 2-3 sec of startup. I use 5W30.
The block heater is for the antifreeze; rig will warm up faster with one. That said, make sure your antifreeze is the proper 'freeze/water ratio. I run mine at 60/40 for up here. Most parts places have them; you need to call and ask your dealer, esp if the rig is still under warranty.
I also use a heat pad for the battery. Keep in mind with living there that you NEVER, EVER jump nor charge a frozen battery. This is a BIG safety no-no.
If you have trouble finding stuff, shoot me a PM and I'll get some quotes/part numbers for you. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5868 MB (Peak: 0.6349 MB) Data Comp: Off Server Time: 2026-06-12 13:05:07 UTC
