Page 2 of 3 1 2 3
Re: Montero Type 1 Questions [Re: MontyMcV] #906435 09/21/08 03:19 AM
Grasscat Offline
Thanks for the information Bill. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Montero Type 1 Questions [Re: MontyMcV] #906436 09/21/08 03:27 AM
Numerically, probably more 4-cyl Raiders than V6's.
I have the LSD in my Raider and cannot imagine going in the dirt without that at least. My wife and I financed our first car, an 86 Montero with open axles. I would have changed several things had I known about Montero parts then.
I can't help with Weber stuff. LSD, yes. Weber, probably. Vacuum lines should be pretty simple compared to the Mikuni. 1: signal for the power booster, 2: signal for the vacuum advance on the dizzy, 3: signal for the vapor recovery, 4: signal for the PCV. What else?
Lastly, welcome to the 4x4Wire!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Russell
Re: Montero Type 1 Questions [Re: rxinhed] #906437 09/21/08 05:37 AM
G
gilamontero Offline OP
Thanks for the info.
Does your choke work well on the weber? Mine seems to have a low fast idle.
My parts Raider is a 2.6 with an auto.
I have parts I don't need that I am going to post before I scrap it.
I have to go to emissions testing in January and I am a little worried.
Re: Montero Type 1 Questions [Re: gilamontero] #906438 09/21/08 09:54 AM
W
WagonMaster Offline
You could register it via a PO box in Eastern Washington and skip the emissions test...
PITA, but do-able.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: Montero Type 1 Questions [Re: gilamontero] #906439 09/22/08 04:43 AM
W
WagonMaster Offline
gila,
If you are not going to use the rear seatbelts, I'd love to buy them. The previous owner of my Raider had a dog, and now there are no belts in back. Makes it hard to carry the family, and my 4 year old daughter is DYING to take a ride in the truck... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Montero Type 1 Questions [Re: WagonMaster] #906440 09/23/08 02:07 AM
G
Wagonmaster, What part of the seat belts do you need? What is your email address or phone #? I live near Renton.
Has anyone put shoulder seat belts in the rear od their swb? It looks like there is a threaded insert that could accept the upper mount.
Re: Montero Type 1 Questions [Re: gilamontero] #906441 09/23/08 03:36 AM
I put three-point belts in my 87. There is the bolt hole high, and the recoilers go behind the panels above the wheel wells.
Re: Montero Type 1 Questions [Re: gilamontero] #906442 09/23/08 05:12 AM
W
WagonMaster Offline
gila,
My mistake. I assumed that yours WERE 3 point, as my 89s are. I'll need to replace with 3 pointers for the kid seat to work. 3 pointers from 4-door rigs will NOT interchange with the 2-door units in the Gen I's.
Re: Montero Type 1 Questions [Re: MontyMcV] #906443 09/23/08 05:25 AM
G
Monty, what type of 3 points did you use? Can I adapt the belts from the front of my parts swb. Any pictures.
Side note: I capped all my vacuum lines except the line to the distributor. Weber works much better now.
Re: Montero Type 1 Questions [Re: gilamontero] #906444 09/23/08 05:37 AM
W
WagonMaster Offline
Without actually taking them out, it looks like fronts belts will interchange between the 4-door and 2-door Gen I's. Front belts will NOT interchange with rear belts in the 2-door.
Wagon Master
"If it ain't Wagon, you ain't the Master"
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6402 MB (Peak: 0.7480 MB) Data Comp: Off Server Time: 2026-06-21 19:03:20 UTC
