Re: Montero Type 1 Questions
[Re: MontyMcV]
#906435
09/21/08 03:19 AM
Thanks for the information Bill. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Michael j
TreadLightly! Trainer
[Re: MontyMcV]
#906436
09/21/08 03:27 AM
Numerically, probably more 4-cyl Raiders than V6's.
I have the LSD in my Raider and cannot imagine going in the dirt without that at least. My wife and I financed our first car, an 86 Montero with open axles. I would have changed several things had I known about Montero parts then.
I can't help with Weber stuff. LSD, yes. Weber, probably. Vacuum lines should be pretty simple compared to the Mikuni. 1: signal for the power booster, 2: signal for the vacuum advance on the dizzy, 3: signal for the vapor recovery, 4: signal for the PCV. What else?
Lastly, welcome to the 4x4Wire!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Russell
[Re: rxinhed]
#906437
09/21/08 05:37 AM
Thanks for the info.
Does your choke work well on the weber? Mine seems to have a low fast idle.
My parts Raider is a 2.6 with an auto. I have parts I don't need that I am going to post before I scrap it.
I have to go to emissions testing in January and I am a little worried.
[Re: gilamontero]
#906438
09/21/08 09:54 AM
You could register it via a PO box in Eastern Washington and skip the emissions test...
PITA, but do-able.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
[Re: gilamontero]
#906439
09/22/08 04:43 AM
gila,
If you are not going to use the rear seatbelts, I'd love to buy them. The previous owner of my Raider had a dog, and now there are no belts in back. Makes it hard to carry the family, and my 4 year old daughter is DYING to take a ride in the truck... <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: WagonMaster]
#906440
09/23/08 02:07 AM
Wagonmaster, What part of the seat belts do you need? What is your email address or phone #? I live near Renton.
Has anyone put shoulder seat belts in the rear od their swb? It looks like there is a threaded insert that could accept the upper mount.
[Re: gilamontero]
#906441
09/23/08 03:36 AM
I put three-point belts in my 87. There is the bolt hole high, and the recoilers go behind the panels above the wheel wells.
[Re: gilamontero]
#906442
09/23/08 05:12 AM
gila,
My mistake. I assumed that yours WERE 3 point, as my 89s are. I'll need to replace with 3 pointers for the kid seat to work. 3 pointers from 4-door rigs will NOT interchange with the 2-door units in the Gen I's.
[Re: MontyMcV]
#906443
09/23/08 05:25 AM
Monty, what type of 3 points did you use? Can I adapt the belts from the front of my parts swb. Any pictures.
Side note: I capped all my vacuum lines except the line to the distributor. Weber works much better now.
[Re: gilamontero]
#906444
09/23/08 05:37 AM
Without actually taking them out, it looks like fronts belts will interchange between the 4-door and 2-door Gen I's. Front belts will NOT interchange with rear belts in the 2-door.
Wagon Master "If it ain't Wagon, you ain't the Master"
