valve cover vent hose
#906583
09/21/08 11:18 AM
Hey has anyone out there moved the hose that goes from the valve cover to the turbo intake hose. Also is anyone else's spewing oil into the turbo. Took mine out since i made my snorkel and routed it into a 1 quart oil bottle. has anyone else done anything else different to keep all that bad oil out of the turbo let me know thanks.
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED 1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW CURRENTLY LOCATED IN JAPAN
Re: valve cover vent hose
[Re: drtydzl]
#906584
09/22/08 02:11 AM
It is an oil cooled turbo... where is the confusion ??? If you were worried about 'bad oil' getting into the turbo then you shouldn't have bought a diesel as they run dirty. Oil and filter every 5,000kms and you'll be fine. As far as the 'quart bottle bypass' I commend you for trying, but I think its a bit much. <img src="/forums/images/graemlins/confused.gif" alt="" />
1990 Mitsubishi Pajero 2.5tdi NG 31" Dueler A/T Winter pack Bright Lights
[Re: Kurt1230]
#906585
09/22/08 08:52 AM
I presume you are referring to the positive crankcase ventilation?
Sure you can re-route the pipe into a bottle, but then your engine is violating emission regulations in just about every state and country in the world.
Why not fit a Raco CCV4500 crankcase ventilation filter (or similar) and stay inside the law?
If your engine is in good nick, the oil content in the ventilated air should not be not that much, IAC. Maybe that high boost turbo is effecting your engine?
Don't ascribe to malice anything that can be adequately explained as stupidity! Pajero LWB Gen1 3.2 Di-D TD Engine 33" Bridgestone D694s 2" Lift Front Runner Rack
[Re: 4ePajero]
#906586
09/22/08 12:14 PM
I was thinking that the boost level was some what to blame that seems to be the only side affect i have noticed so far pictures should be view able now let me know snorkel pics to come this weekend
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.017s) Memory: 0.6025 MB (Peak: 0.6588 MB) Data Comp: Off Server Time: 2026-11-20 00:39:33 UTCValid HTML 5 and Valid CSS
