Throttle body #907155 09/25/08 01:50 AM
F
fstowe Offline OP
Are the poweraid throttle body spacers any good? Can`t see them being any good for port injection.but what about thottle body?
Re: Throttle body [Re: fstowe] #907156 09/25/08 02:03 AM
52degrees Offline
Can you explain to me how adding length to the intake makes more power? I can see it if you add fuel at the throttle plate, but otherwise it seems to me as though air is air.
KG6VNX
Re: Throttle body [Re: 52degrees] #907157 09/26/08 03:08 AM
F
fstowe Offline OP
So is that a NO or does it create a vortec the one i`ve seen has grooves in it.
Re: Throttle body [Re: fstowe] #907158 09/26/08 06:51 AM
52degrees Offline
The debate is ongoing. What I believe is that the only performance gains you'll realize will be the result of the computer changing the shift points and fuel trim to adjust for your new, more aggressive driving habits trying out your new "perfoming enhancing products".
But then, I'm no longer a GM drivability tech (15 months out of the business), so what do I know? <img src="/forums/images/graemlins/wink.gif" alt="" />
In short, no. I don't think you'll do anything by adding it other than add another potential air leak after the airflow meter. I wouldn't touch it with a 10-foot pole.
KG6VNX
Re: Throttle body [Re: 52degrees] #907159 09/26/08 06:56 AM
52degrees Offline
Wait... You said TBI, right? It may help with low-end torque. It may also cause all kinds of problems. One could be that your hood may not shut without bending the air filter assembly. Or you may find that you have a nervous idle. Or your top-end performance may be seriously degraded.
Basically, you may end up with a really good running engine in the RPM and torque range you want, or it could be a total nightmare.
KG6VNX
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6041 MB (Peak: 0.6685 MB) Data Comp: Off Server Time: 2026-06-08 10:04:33 UTC
