synchromesh
#907487
09/27/08 05:23 PM
is synchromesh ok for TC and MT?
thanks
Re: synchromesh
[Re: 85Montero]
#907488
09/27/08 05:55 PM
torqe convertor and manual trans.?
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: synchromesh
[Re: 93montero_sr]
#907489
09/27/08 06:03 PM
Re: synchromesh
[Re: 85Montero]
#907490
09/27/08 11:44 PM
I would think so. My VR4 that I got from someone used it cause of the slight griding it has when shifting on the fly into 2nd and 3rd. Synchromesh should help absorb some of that and help it shift a lil smoother, but wil not fix your problem in the long run. Its usually good for 10k. I plan on trying it out myself
Re: synchromesh
[Re: 93montero_sr]
#907491
09/27/08 11:44 PM
I would think of no advantage to Pennsoil Synchromesh.The t case is kinda primitive and I stil with 80-90wt. Synchro has been used as additive to V6 V5MT1-0 s.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: synchromesh
[Re: KrzyDav]
#907492
09/30/08 01:43 AM
it snchromesh supposed to be an additive or a full on lube to be used in place of other gear lubes?
Re: synchromesh
[Re: 85Montero]
#907493
09/30/08 07:45 PM
I used it as a fill , probably souldn't . It is really watery
