HELP!!!!...Warning lights....
#907905
09/30/08 12:22 AM
1995 T-100 ext cab...3.4 L ...A/T...165K miles... Running good...MPG seems OK... Maintenance has been good...
However, about a month ago the seatbelt/airbag warning light started staying on... Then two days ago, the engine warning light started staying on... Checked all fluid levels...OK And the engine is running fine... Is this a sensor going bad...or an electrical problem?
I love my 'lil T-100...and wanna get some more good miles outta her... Any help would be much appreciated...
Thanks in advance....
Re: HELP!!!!...Warning lights....
[Re: Kapuna]
#907906
09/30/08 01:01 AM
take it into a shop or dealership and have them check for DTC's. it'll tell ya whats wrong, and they'll advise the best way to fix it. it'll cost a little bit. my dealership is an hour of labor, which is $98.
formerly 277000_yota Old enough to know better, but still to damn arrogant to care... ]www.cardomain.com/ride/2614269'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P) '98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
[Re: IceBlueT]
#907907
09/30/08 09:18 PM
Toyota Moderator
A lot of places like Autozone will pull the codes for free, then you can use a service manual or look them up online to find out what they are and decide whether or not its something you can fix yourself...
[Re: Kapuna]
#907908
10/01/08 08:00 PM
The seat belt light is controlled by the 'integration relay' on the back of the fuse box. This thing is pretty 'dumb' there is no real way to ask it whats going on.
The engine and airbag can store fault codes. The engine is easy to read with a universal OBD2 scanner. The airbag may blink codes out at you when you add a jumper somewhere.
But, since you have lights coming on from different systems, look at the battery and charging system. What else could be common to all these parts?
97 T100 4x4 97 328i 95 540i restoration project
[Re: eleet]
#907909
10/04/08 12:26 AM
Ran a computer scan... All things point to the O2 Sensor.... Gonna pull it and take a look... Wonder where the best prices are?
Thanks, guys...
PHP: 7.4.33 Page Time: 1.515s Queries: 15 (0.003s) Memory: 0.6046 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-05-29 21:28:25 UTCValid HTML 5 and Valid CSS
